Remote Starter Bad? Good?
Old Nov 22, 2004 | 04:36 PM
racingfan's Avatar
Default Remote Starter Bad? Good?
does a remote starter bad for a manuel transmission car?
Old Nov 22, 2004 | 04:51 PM
fcm's Avatar
fcm
Old Fart
Default Re: Remote Starter Bad? Good? (Wayne99-Turbo GS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wayne99-Turbo GS-R &raquo;</TD></TR><TR><TD CLASS="quote">does a remote starter bad for a manuel transmission car?</TD></TR></TABLE> No, just get one for a standerd 94
Old Nov 22, 2004 | 07:52 PM
racingfan's Avatar
Default Re: Remote Starter Bad? Good? (fcm)
its bad for the car if you use it all the time?
Old Nov 22, 2004 | 08:27 PM
sopiwnykg's Avatar
no it isn't bad at all
Old Nov 23, 2004 | 12:16 AM
Kyles ej1's Avatar
Default Re: Remote Starter Bad? Good? (sopiwnykg)
only if you keep it in gear
Old Nov 23, 2004 | 12:24 AM
EK k kay's Avatar
Default Re: Remote Starter Bad? Good? (egcoupe)
It'll make your manual push button kill switches useless though.
Old Nov 23, 2004 | 06:56 AM
was
Default Re: Remote Starter Bad? Good? (chowmien)
no its not bad! thats a dumb question.... all it does is crank your car for you... is it bad when you start your car?
just dont leave it in gear...
Old Nov 23, 2004 | 10:27 AM
itr_dc2's Avatar
Default Re: Remote Starter Bad? Good? (boosted y8)
its only bad if the installer sets the crank longer than it should be.
IE: sets it for cold start crank which could turn over for 2 seconds. vs. a warm crank of 1 second.
Just make sure its set up properly and you'll have no problems.
Old Nov 24, 2004 | 07:39 AM
fcm's Avatar
fcm
Old Fart
Default Re: Remote Starter Bad? Good? (itr_dc2)
They make remote starts for manual trans. cars, [no way to leave it in gear, and be able to use the remote start, and how long it cranks depends on how long it takes your car to start, [crank time useing remote start will be shorter then with key] remote start cranking stops as soon as motor starts, [it sees the RPMs] 94
Old Nov 25, 2004 | 02:52 PM
GoFastTshirts.com's Avatar
how does it get passed the clutch having to be pushed down to start the car ?
Old Nov 25, 2004 | 04:40 PM
fcm's Avatar
fcm
Old Fart
Default Re: Remote Starter Bad? Good? (RexOwner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RexOwner &raquo;</TD></TR><TR><TD CLASS="quote">how does it get passed the clutch having to be pushed down to start the car ?</TD></TR></TABLE>Depends on car, but at the most you install a relay that closes the circuit, the relay is tripped by the "on when running" output of the remote start. 94
Old Dec 2, 2004 | 10:32 PM
was
it bypasses the clutch wire...all you do is ground it... the most important part of it, is to make sure your brake wire is hooked up, that way, if someone depresses your brake, your car will shut off...
Old Dec 3, 2004 | 05:03 AM
jonyb's Avatar
Have'nt we been through this several times before?
Old Dec 3, 2004 | 05:20 AM
DohcSide's Avatar
Default Re: Remote Starter Bad? Good? (99Suzuka Blue GS-R)
so all those rumors about remote starters are false? i thought in the long run remote starters are bad?
Old Dec 3, 2004 | 05:26 AM
B18C_EJ8's Avatar
All a remote starter does is perform the exact same function that your key does, only without the key. It just uses relays to simulate turning the key. Is starting your car with the key bad in the long run?
b18cEK
21
Apr 9, 2014 07:14 PM
Hectorzg1
Jul 28, 2010 08:03 PM
Philip
10
Dec 30, 2006 05:01 PM
97LXAcc0rd
Sep 28, 2005 11:18 AM
GQ 05YellowEVO8
Aug 12, 2002 07:08 PM
