Remote Start Install Help
Old Dec 15, 2004 | 07:58 PM
AlxSiR7's Avatar
Default Remote Start Install Help
Just bought the Clifford Matrix RS for my girls car & want to install it for her before Xmas. Are there any write up's out there? I can't imagine this being too hard.. if anyone has any tips let me know!
Old Dec 16, 2004 | 08:13 AM
fcm's Avatar
fcm
Old Fart
Default Re: Remote Start Install Help (AlxSiR7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlxSiR7 &raquo;</TD></TR><TR><TD CLASS="quote">Just bought the Clifford Matrix RS for my girls car & want to install it for her before Xmas. Are there any write up's out there? I can't imagine this being too hard.. if anyone has any tips let me know!</TD></TR></TABLE> link http://www.bulldogsecurity.com for wire tagin, that said, if you haven't installed one ,or an alarm, it is more complex then poping in a HU. 94
Old Dec 16, 2004 | 08:18 AM
AlxSiR7's Avatar
Default Re: Remote Start Install Help (fcm)
hm..alright.. anyone else?
Old Dec 16, 2004 | 08:58 AM
audioroach's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlxSiR7 &raquo;</TD></TR><TR><TD CLASS="quote">hm..alright.. anyone else?</TD></TR></TABLE>
As FCM stated Before...A Security system is a lot more complicated than installing
a radio..not really for a novice. If you are up to the challenge and have several
hours or days avail to you
then go for it. If not turn it over to the professionals.
have fun
Old Dec 16, 2004 | 11:33 AM
AlxSiR7's Avatar
Default Re: Remote Start Install Help (audioroach)
yea.. but all the relays are pre-wired, so it makes it somewhat easier... programming the remote will be in the manual.. and the rest is just wiring to the locks, horn, ignition, + & -...
Old Dec 16, 2004 | 08:44 PM
kwhitelaw's Avatar
Honestly,and I don't know your experience level, but if you have never tackled an alarm install before, don't startnow on your girls car. She'll be hating you if it gets weird or stops working. Alarms are all about the install. If you can't devote the proper time/attention to detail to install it right, you may as well wire it and leave it on the seat.
That being said, you won't need to program the remote. Put the battery in and hit the button. Also, I would install a backup battery and backup battery siren while you are in there.
Old Dec 17, 2004 | 07:58 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlxSiR7 &raquo;</TD></TR><TR><TD CLASS="quote">yea.. but all the relays are pre-wired, so it makes it somewhat easier... programming the remote will be in the manual.. and the rest is just wiring to the locks, horn, ignition, + & -...</TD></TR></TABLE>Im not saying you can't do it , if you feel up to it, go for it, I will try to help . Here is a hint list, and tool you will need
1- tools.... multimeter, [or ECU safe testlight] solder gun, [or solder station] 60/40 resin core solder, wire strippers , depinning tools, elec. tape, wire tyes, [zip tyes] and whatever tools needed to take apart the drivers side underdash.
2- you will need a wire guide, [tag in guide] http://www.bulldogsecurity.com.
3- the install guide for the remote start
Hints
1- check and test each wire you are tagging into, [make sure it is what bulldog says it is] its very inportant.
2- every wire you need to tag into, has a plug somewere along its path, [that can be unplugged, the metal pin in the plastic plug on that wire, can be depined, and and you can solder the remote starts wire to that pin, [ making sure not to interfear with being able to reinstall pin back into plug] or you can do it the old school way and strip the insulation off the wire, [about 1/4" to 1/2"] and wrap the remotes wire around it and solder and wrap it in elec. tape .
3- all the ign. wires, [the ones on the relaypack] powers x2, acc., start, and the two ign. wires, [you may only need one ign.] can be done on the ign. harness, all the rest will be taged in around or on the fuse box, except the hoodpin and the tech, [they go into engine bay] and the brake sense, [it is taged in at the brake switch]
I hope this helps, you can IM me if you you have a Q, I will get back to you as soon as I read it.
Good luck 94
Old Dec 17, 2004 | 01:10 PM
AlxSiR7's Avatar
that really helps.. thanks. i'll pm you if i run into any problems.
Old Dec 17, 2004 | 01:21 PM
AlxSiR7's Avatar
does anyone have the actual clifford rs instructions that can be scanned for me if they arent already online?? i looked and can't find any...
Old Dec 18, 2004 | 11:29 AM
philly-O's Avatar
should be standard DEI wire colors.
dont forget that the install will make or break the alarms performance.
goodluck with the install
Old Dec 18, 2004 | 11:50 AM
AlxSiR7's Avatar
Default Re: Remote Start Install Help (peichie)
what are the standard dei colors? i already have a chart that has the factory wire colors..
Old Dec 28, 2004 | 06:36 PM
SiR-ed8's Avatar
Curious, how much does it cost to install just that feature? The idiots who wired my alarm failed to wire the remote start feature. I can only guess as to what else they forgot or screwed up in.
I'm not going to try and wire it myself. I'll head over to the alarm shop that installed my alarm accessories for the RSX3.5.
Please any help is greatly appreciated. Thank you very much
Old Dec 29, 2004 | 06:52 AM
fcm's Avatar
fcm
Old Fart
Default Re: Remote Start Install Help (SiR-ed8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR-ed8 &raquo;</TD></TR><TR><TD CLASS="quote">Curious, how much does it cost to install just that feature? The idiots who wired my alarm failed to wire the remote start feature. I can only guess as to what else they forgot or screwed up in.
Please any help is greatly appreciated. Thank you very much</TD></TR></TABLE>If you have a manual trans. and the remote start is for auto. trans. only , most shops will not hook up the starter. 94
Old Dec 29, 2004 | 09:41 AM
SiR-ed8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">If you have a manual trans. and the remote start is for auto. trans. only , most shops will not hook up the starter. 94</TD></TR></TABLE>
Oh man that sucks, i hope that isn't the case for me. I'll be heading out today if the rain clears up. Thanks again
Old Dec 29, 2004 | 03:09 PM
SiR-ed8's Avatar
Well the shop i went to said since he couldn't reach for the clutch wires he's not going to bother with the effort. Reason being, there's too much testing involved. Guess he doesn't like money.
It's understanbable because he nor his guys didn't work on the install originally. There's so many relays involved that he doesn't want to screw it up. Hell I myself wouldn't touch it ( even if i had alarm experience ). Unfortunately the two guys that worked on my alarm accessories install weren't there.
I asked him how much he would charge for this particular case. He said $150 at most.
Damn, i'm going to try another shop tomorrow with my friend. Hopefully that doesn't fall through as well.
vietherbs
Honda S2000
May 28, 2006 03:13 PM
LAOS
Audio / Security / Video
Aug 26, 2005 03:41 PM
DrewQ1
May 9, 2005 06:23 PM
DRKSol
May 9, 2004 05:50 PM
Touch
11
Jun 15, 2003 01:24 AM
