Remote Start?
Old Aug 14, 2004 | 01:59 AM
bryandamatrix's Avatar
Default Remote Start?
Is there a way i can tweak or modify my engine run time?
i can only program my remote starter from 12 or 24 minutes.
i want to modify it for 5 minutes engine run time is it possible?
IF so how to do it??
Old Aug 14, 2004 | 05:23 AM
rjr162's Avatar
Default Re: Remote Start? (bryandamatrix)
depending on the brand you can change it. If you have a DEI viper series you can go to a DEI dealer and have them program it wtih the bit writer. Otherwise, you're stuck with the 12,24, or 60 minutes
Old Aug 20, 2004 | 11:09 PM
Default Re: Remote Start? (rjr162)
remote starter want window down 12:56 AM 8/19/2004 Reply Edit
how do i install this?
i want my window to roll down instead on putting my trunk realease?
system auxiliry output.
how do i do this?
what wire should i connect to the window wiring?
auxilary output (-) 500ma
or auxilary start (-) input ????
i need help ....
my remote starter is already hook up and its working good.
I just need the info on how to connect the wire to roll down the window when i press the trunk releasee button?
PS: i have trouble finding the window wire ....where is this located drivers side switch??????
Power Window Left Up(+) Red/Blue Driver's Side Switch
Power Window Left Down(+) Red/Yellow Driver's Side Switch
Power Window Right Up(+) Blue/Yellow Driver's Side Switch
Power Window Right Down(+) Blue/Green Driver's Side Switch
Old Aug 21, 2004 | 07:42 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryandamatrix &raquo;</TD></TR><TR><TD CLASS="quote"> remote starter want window down 12:56 AM 8/19/2004 Reply Edit
how do i do this?
i need help ....
</TD></TR></TABLE> You will need a Dei 529t or 530t window mod,[ or other brand ] hook up will be done in drivers door on all Hondas that have auto down drivers window. 94
Canadian_EF
Audio / Security / Video
Jul 23, 2012 09:04 AM
ftrms
Feb 18, 2011 09:17 PM
slowjett
Dec 26, 2006 08:55 PM
EScustomz
Honda S2000
32
Nov 20, 2005 06:29 PM
technine
Aug 23, 2002 05:42 PM
