relay help !!!!!
sorry if in wrong section, lots of people look in this section so i post up until i get my help, then ill delete.
installing an alarm in my car, i have to hook up a relay for a set of wires.... im confused..
(POWER DOOR LOCKS 6-pin)
this is how the diagram is pictured...
--------------brown (unlock switch) n/c 87a
--------------blue (unlock motor) ...common 30
--------------Violet (unlock) n/o 87
--------------White (lock switch) n/c 87a
--------------Green (lock motor) ...common 30
--------------Violet/Red (lock) n/o 87
then it says... coil contacts 85 &n86 are not needed as they are controlled within the main unit.
my question is how do i hook these wires up to a relay, if some on them are the same coil contacts ???? im confused on that part...
thanks for any help !!!!
Everything else is hooked up and working, the alarm arms/disarms. ..... it just wont lock/unlock my doors with the button due to this relay problem !!
are your locks nagative or positive locks??? assuming honda you would ground violet and violet red, isolate and cap off brown and white, and green is lock, blue is unlock.
so green is lock ... blue is unlock ... where on the relay these go...
green - 87
blue - 87a
im still confused... if u could write out what wires on what coil contacts that be SOOOO SIIIICK !!
thanks for helping and fast response !!
green - 87
blue - 87a
Does it have the option for the 2 wire lock/unlock setup because with these honda's since they are a negative locking system you dont really need the relay as you are only supplying a ground pulse and not a positive pulse with any sort of current
Try just hooking up the Blue and green wires to your lock/unlock and it should work, Otherwise you will need to ground violet and violet/red if I am not mistaken
mikeycivic
Audio / Security / Video
48
Nov 29, 2009 08:48 AM
stephen_civic98
Mar 18, 2007 05:13 PM
Lex2Go
Jul 14, 2005 07:31 PM
powerfulperformance
Oct 11, 2003 04:36 PM
