Real Noob question about sub install
Old Aug 21, 2006 | 11:36 AM
ITR EG's Avatar
Default Real Noob question about sub install
Right off the bat I apoligize for being so ignorant. I just got a 12" JL audio sub. I know absolutly nothing about car audio systems. I can't hook the sub right up to the RCA ouputs on the headunit can I? If not I will need an amp. Here is where I have no clue as too what I am looking for. I don't know what brand or size amp I need and I have no idea what features I need. I am sure once I get everything I will be able to install myself, I just need some help on what I need. Thanks guys, and again, sorry for my extreme lack of knowledge in this area.
Old Aug 21, 2006 | 12:02 PM
fcm's Avatar
fcm
Old Fart
Default Re: Real Noob question about sub install (ITR EG)
No, it can't be hooked to the RCAs, yes, you will need an amp.
What is the model of the JL sub? 94
Old Aug 21, 2006 | 12:44 PM
ITR EG's Avatar
Default Re: Real Noob question about sub install (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> No, it can't be hooked to the RCAs, yes, you will need an amp.
What is the model of the JL sub? 94</TD></TR></TABLE>
The sub is 12w0 8 ohm.
Old Aug 21, 2006 | 02:01 PM
CRX_Phantom1's Avatar
a JL 250/1 should be plenty to power that sub....as for connections...you will need a set of RCA's to go from the amp to the HU. Then run ur speaker, power, ground and remote wires as necessary. That should work for ya
Old Aug 21, 2006 | 02:20 PM
ITR EG's Avatar
Default Re: Real Noob question about sub install (CRX_Phantom1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Phantom1 &raquo;</TD></TR><TR><TD CLASS="quote">a JL 250/1 should be plenty to power that sub....as for connections...you will need a set of RCA's to go from the amp to the HU. Then run ur speaker, power, ground and remote wires as necessary. That should work for ya</TD></TR></TABLE>
All of the wiring instructions should come with the amp, right? Do I have to run the speaker wires to the amp? I thought I just ran them off the headunit. All I want to run off of the amp is the sub.
Old Aug 21, 2006 | 03:44 PM
Odessa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR EG &raquo;</TD></TR><TR><TD CLASS="quote">All of the wiring instructions should come with the amp, right? Do I have to run the speaker wires to the amp? I thought I just ran them off the headunit. All I want to run off of the amp is the sub.</TD></TR></TABLE>
You run (speaker) wire from amp to sub, which has nothing to do with normal car speakers, if that's what you wanted to know.
Old Aug 21, 2006 | 04:27 PM
yes all wiring instructions come with the amp....like Odessa said, you run the speaker wire from the amp to the sub. You have to run the RCA cables to the output wires on the back of the headunit.
Old Aug 21, 2006 | 04:28 PM
ITR EG's Avatar
yes all wiring instructions come with the amp....like Odessa said, you run the speaker wire from the amp to the sub. You have to run the RCA cables to the output wires on the back of the headunit.</TD></TR></TABLE>
And then all I need to run is power and ground?
Old Aug 21, 2006 | 04:31 PM
power, ground and remote wire. The remote wire runs from the amp to the headunit. Usually its a blue wire on the back of the headunit. This allows the amp to turn on and off with the headunit. Im running 3 12w3's in my truck
Old Aug 21, 2006 | 07:19 PM
ITR EG's Avatar
Thanks for all the help guys, this seems pretty straight forward. All I need now is an amp, so if anyone has one that will work for my application, let me know.
Old Aug 22, 2006 | 04:29 AM
ITR EG's Avatar
One more quick question, Do I run the power and ground straight to the battery, or do I ground it somewhere in the trunk?
Old Aug 22, 2006 | 09:19 AM
fcm's Avatar
fcm
Old Fart
The 12W0-8 is a 125W "RMS", [continuous power handling], you will need an amp that makes 1x125W RMS into 8 ohms or 1x250W RMS into 4 ohms.
The JL Audio 250/1 makes 250W RMS into 1.5 -4 ohms @ 11V-14.5V, it is a regulated "output" however if connected to 8 ohms it will make 125W and as CRX_Phanton1 suggests it would make a perfect amp for that sub.
Ground the amp, with as short a ground lead as you can use, to the floor pan of the car, seat and seat belt bolts work very well, also I should mention the JL Audio amps are less the 2.5" high and will fit under the pass seat on most, [if not all] Honda/Acuras, this will keep the power lead as short as possible as well as the RCA cable, and you have 4 seat bolts to choose from to ground the amp. 94
Old Aug 22, 2006 | 12:10 PM
ITR EG's Avatar
I was planning on mounting the amp to the sub box. Is that a good idea?
Old Aug 22, 2006 | 02:50 PM
you need to mount it somewhere that gets good ventalation. Dont want it to overheat.
Old Aug 22, 2006 | 04:00 PM
nsxxtreme's Avatar
you might check here http://www.onlinecarstereo.com...yID=1
You also might post a price range so people can give you some options.
Old Aug 22, 2006 | 06:12 PM
ITR EG's Avatar
Default Re: (nsxxtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">you might check here http://www.onlinecarstereo.com...yID=1
You also might post a price range so people can give you some options.</TD></TR></TABLE>
I am looking to spend under $100, preferably less.
Old Aug 22, 2006 | 06:17 PM
mrdeadman's Avatar
They let me pick
Default Re: (ITR EG)
I am looking to spend under $100, preferably less.</TD></TR></TABLE>
Haha. Have fun trying to find an amp for less than 100 bones unless it's used.
Old Aug 22, 2006 | 07:15 PM
ITR EG's Avatar
Default Re: (mrdeadman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">
Haha. Have fun trying to find an amp for less than 100 bones unless it's used. </TD></TR></TABLE>
I'm looking for a used one.
Old Aug 22, 2006 | 07:44 PM
mrdeadman's Avatar
They let me pick
I wouldn't mount the amp on the box if I were you. The box is a pretty bad place to be for an amp. Mount it under a seat or something.
Old Aug 22, 2006 | 09:48 PM
nsxxtreme's Avatar
you might look here http://cgi.ebay.com/Autotek-Me...wItem
you might stretch your budget a little a get one of these http://www.zedaudio.com/store.html
You wont find a better amp for the price.
Both amps were designed by the same person.
Modified by nsxxtreme at 11:10 PM 8/22/2006
Old Aug 23, 2006 | 04:24 AM
SkorchedAsh's Avatar
wow....crutchfield has a great tutorial video on basic sub install...go look for it, it will help you lots, it really helped me
Old Aug 23, 2006 | 09:44 AM
yea i doubt you will find a JL 250/1 for under $100. even a used one
Old Aug 23, 2006 | 09:31 PM
Singlecam4dr's Avatar
Default Re: (CRX_Phantom1)
i gota 10w1v2 JL wit a clarion amp hits as hard as i need it to its a APX2120 i got for a hundred new from my local stereo store
jdmCD695
Sep 22, 2008 12:06 AM
nyzd79
Audio / Security / Video
Jan 18, 2008 02:58 PM
jdmotorsports
Sep 19, 2007 04:15 AM
civichatchb18c
Dec 19, 2004 08:47 AM
ls-t del sol
Dec 16, 2003 02:00 PM
