Rattling In the TRUNK
Old Oct 4, 2007 | 08:15 AM
'Accord Ex''s Avatar
Default Rattling In the TRUNK
Well My trunk rattles quite a bit so I installed some Dyno Mat and it is a lot better but still not what I would like. I was going to install roof instalation to make less rattle. do you have any other Ideas? Thanks?
Old Oct 4, 2007 | 11:01 AM
bpr0422's Avatar
Default Re: Rattling In the TRUNK ('Accord Ex')
i guess you own an accord...
its dynamat ... not dnyo mat.. unless that is some knock off brand..
rattle can come from lots of things, from loose wires, cables, loose tail lamps, etc..
use some sticky double sided foam or just some art foam in between items that are loose... your license plate.. and the frame... if you have a spoiler.. it might rattle...
make sure you just secure everything with some padding in between it and the sheet metal
Old Oct 4, 2007 | 03:29 PM
EvenStar's Avatar
I was going to make a topic as well about how to stop the rattling in the trunk. And I do get annoyed of it all the time.
Anyways, are dynamats installed at most audio shops? What about Circuit City?
Old Oct 7, 2007 | 06:39 AM
1992hatchsi's Avatar
Default Re: (EvenStar)
before my honda i had a dodge stratus with a competition level stereo. I used close to 350-400 dollars in dynamat on the floor and trunk lid. i still had an annoying rattle that turned out to be my rear 6x9 deck. That made the sound alot more enjoyable from the inside of the car as well as the outside.
HeatherAnn32
Feb 1, 2013 11:44 AM
Mylinh
May 31, 2011 03:09 PM
cats_on_ice
Jul 14, 2006 10:11 PM
H22CD
May 28, 2006 05:17 PM
B18cteg
Jun 9, 2003 07:56 AM
