Radio installation troubles
Old Jun 21, 2004 | 04:58 PM
teknowaffle's Avatar
Default Radio installation troubles
I am trying to install a new CD player in my accord, but i can't get it to work. I know that there is power flowing through the battery cord, so i think the problem is with the ACC. The Ciggarette lighter won't work either, so i think there may be a common problem between them, and i know that it isn't a fuse. Thanks
Old Jun 21, 2004 | 05:20 PM
lakas187's Avatar
Default Re: Radio installation troubles (teknowaffle)
Just join both red,& yellow wire's coming from your deck together, to the hot wire coming from your accord's harness.
Old Jun 22, 2004 | 04:28 AM
Goatsterrman's Avatar
Default Re: Radio installation troubles (lakas187)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lakas187 &raquo;</TD></TR><TR><TD CLASS="quote">Just join both red,& yellow wire's coming from your deck together, to the hot wire coming from your accord's harness.</TD></TR></TABLE>
Do not take this advice, this will not allow you the radio to turn on and off with the car, you will have to turn power off the radio every time you get in and out the car.
Chances are that it is a blown fuse somewhere. Check the fuses with a multimeter, sometimes a fuse might look good and actually not be working. Try to find a bad fuse and replace it, even if it's not designated the radio fuse.
Old Jun 22, 2004 | 05:48 AM
B18C_EJ8's Avatar
LOL.. That was funny... Sad, but funny... Sad because I see this almost every day, when someone "thinks" they know what they're doing, and can't figure out why their deck stays on all the time, or won't hold presets or bass/treble adjustments, and ends up paying me to have the deck installed "the right way"...
Old Jun 22, 2004 | 06:03 AM
Xsi's Avatar
Xsi
Check your cig lighter fuse man, chances are they're the same
Old Jun 22, 2004 | 12:05 PM
Default Re: (Xsi)
you wouldn't know which one that is, would you, because all my fuses look fine
Old Jun 22, 2004 | 12:34 PM
Nikoli's Avatar
Default Re: (teknowaffle)
yup...blown fuse
i had this same problem
LSP's Avatar
LSP
i got 10 bucks that say your cig lighter fuse is blown.
Old Jun 22, 2004 | 12:41 PM
nOOber's Avatar
the magic fuse is under the hood.
hondaboyqj
Feb 5, 2019 06:28 PM
Freckles
Audio / Security / Video
Dec 19, 2011 12:11 PM
DC2_Legend
Oct 18, 2007 04:22 PM
Leo C
Jan 13, 2007 02:18 PM
teknowaffle
Jun 24, 2004 02:56 AM
