Radio going out randomly?
Old Feb 2, 2007 | 09:54 PM
Sundown's Avatar
Default Radio going out randomly?
My girlfriend's Dual Headunit lately has been acting up lately, and I honestly cannot figure out what the problem is. What is happening is that we will be listening to the radio, and it will randomly just go to static on all channels. I can however switch to CD, and it will play just fine. I have reinstalled the headunit twice and still cannot figure out what is going on. Has anyone else had a problem similar to this, and if so, what did you do to fix it? Thanks
I have checked the antenna hookup in the back, and its plugged completely in.
Old Feb 3, 2007 | 07:01 AM
B18C_EJ8's Avatar
First of all, your main problem is that it's a Dual.
If it's resetting and working fine when you switch sources and then back again, it's most likely a logic problem in the deck, which is not something you can fix.
It sounds like it either needs repair or replacement... Hope you bought some sort of service plan or extended warranty with that deck...
Old Feb 3, 2007 | 08:19 AM
fcm's Avatar
fcm
Old Fart
Default Re: Radio going out randomly? (Sundown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">First of all, your main problem is that it's a Dual.
It sounds like it either needs repair or replacement... Hope you bought some sort of service plan or extended warranty with that deck...</TD></TR></TABLE> I will have to agree.
The only other possibility, [if it's not a problem in the HU itself] is you have an intermittent problem with your cars ant.
Let me ask you this... is the problem there on both AM and FM, if yes then it could be an ant. problem, if no, [no problem on either the FM or the AM] then the problem is definitely in the HU, and sorry it's not worth repairing unless it is under warranty.
Where did you get it and who installed it, [originally] 94
Old Feb 3, 2007 | 01:16 PM
Sundown's Avatar
Hmm ok, well, what I think I may do is put in my OEM cd player in her car since Im not using it, and see what happens from there..
poprocksncoke
Apr 1, 2016 09:58 AM
kyw3
Jan 4, 2009 02:58 PM
vdub17
Oct 28, 2008 08:27 AM
JRizEJ6
Audio / Security / Video
Aug 27, 2006 07:43 AM
-faded-
Sep 29, 2004 04:33 AM
