Radio Code Doesn't Work
Old Jul 21, 2005 | 08:43 PM
Happs's Avatar
Default Radio Code Doesn't Work
A couple days ago, I got my battery replaced on my 1992 Honda Accord EX which naturally reset the radio and asked me to enter a CODE. I have the code and the serial number on the little card but it wasn't in the glove box at the time I got the new battery so I guessed from memory about 3 times with no luck then when I got home, entered the correct code several times with no luck. Tried again 3 hours later, nothing. Again the next day several times throughout the day, nothing. Why is the radio not accepting the correct code? It has in the past. This is the first time something like this has ever happened. Can the dealer help?
Old Jul 22, 2005 | 10:19 AM
fcm's Avatar
fcm
Old Fart
Default Re: Radio Code Doesn't Work (Happs)
You may have to leave the unit on for 3 hr or whatever the wait time is 94
Old Jul 22, 2005 | 11:18 AM
Jeezer's Avatar
maybe you're reading one of the numbers wrong
Old Jul 22, 2005 | 12:44 PM
rjr162's Avatar
Default Re: Radio Code Doesn't Work (fcm)
i've found the quickest route to reset the radio if you enter the wrong code 3 times is to just pull power to the radio again. then enter the correct code.
as for the correct code being labled as wrong... well, I have no clue unless maybe the card got switched for a different one in the past.
Old Jul 22, 2005 | 03:22 PM
EJ4door's Avatar
Your best bet is to take the radio out and bring it to the Honda dealer. They have all the codes on hand. Because I had the problem before and they just gave me the right code
Chris Hart
Mar 23, 2013 04:28 PM
Drtbiker103
Acura TL, RL & ZDX
Dec 26, 2009 04:07 AM
mrsnj20
Sep 5, 2007 03:35 PM
crx_ef8
Acura TL, RL & ZDX
Oct 3, 2003 09:03 AM
SHystrdyGSRtdy
Apr 12, 2003 03:11 PM
