Quicky...
Old Aug 31, 2004 | 09:07 PM
[KGB]Silent's Avatar
Default Quicky...
Is there a way to test out a car cd player to see if it works wihtout attaching it to the car? Just wondering... (like at home what wire is for the power and how can i get the power to work with it?)
one more question while taking off the negative part of the wire from the battery, hand to metal contact!! (-)part , would i get shocked?
And when it says GND, ground or whatever should i tape it to like the dash or any part of the car? (for the cd player)
Thanks
Old Aug 31, 2004 | 09:10 PM
rcurley55's Avatar
New User
short reply - in a house - no, not really --- in the car without installing in the dash - yes
long reply - you could just rig it up to any 12v source - you could hook it straight from the battery if you want - just make sure the wires are fused properly so you don't fry anything. Supply 12v+ to the constant and acc power and attach the ground and you shoud be good to go
Old Sep 1, 2004 | 07:54 AM
nsxxtreme's Avatar
You will not get shocked with 12V unless you stick your tongue on the terminals.
Ground refers to the - terminal on the battery.
You can get shocked from the speaker output of a very powerful amplifier that the volume is turned way up. These terminals can easily see 60+ volts. (its not going to kill you though)
EG.red
May 27, 2009 05:23 PM
Jose-aka-Pedro
Audio / Security / Video
May 13, 2006 01:08 PM
mulletov
Nov 19, 2005 04:50 PM
cory1269
Mar 17, 2004 08:34 PM
DrumminBoy
Dec 29, 2002 05:20 PM
