Quick quetion on sub volume
Old Feb 20, 2007 | 12:56 PM
dizzyek's Avatar
Default Quick quetion on sub volume
I just installed my amp and sub and am about to tune the amp settings.
My deck (pioneer forget which model) has a sub volume feature with 8 levels and an option to go from 80 or 120 forget the measurement.
The default setting on my deck sub control is level 4 and 120.
Should I tune the gain from the highest sub volume on my deck 8 or from the default setting 4?
thanks
Old Feb 20, 2007 | 03:19 PM
fcm's Avatar
fcm
Old Fart
Default Re: Quick quetion on sub volume (dizzyek)
Set your HUs sub out to full, [8], I would also try 80Hz LP x-over setting to start, set HU controls to "flat", [bass and treble] turn off any EQs, [if the HU has an EQ] turn off any loudness or "boost" controles.
Now adjust sub amps gain control for max output, [that does not mean crank the gain to the pin].
With music playing try the 120Hz setting, use the one that sounds the best to you. 94
PS, check your amp it may have a better LP x-over, [continuous from 50Hz to250-500Hz] it may be that 95Hz works better for you.
Old Feb 20, 2007 | 03:29 PM
dizzyek's Avatar
cool thanks for the help.
tigershark
Audio / Security / Video
Jun 15, 2008 02:19 PM
Znypar
10
Mar 14, 2006 08:06 AM
Mark27
Dec 6, 2005 05:35 PM
devilpuppy
Jul 26, 2004 10:11 AM
GoLowDrew
Sep 12, 2003 04:16 PM
