quick question about connectors?
Old Dec 19, 2002 | 02:58 PM
93civdx's Avatar
Default quick question about connectors?
what have you guys found that work best to hook up a 4 guage power and ground to your amp. by this i mean the connectors that you hook to the amp. i've looked around a little bit and i can't seem to find a connector that will hold 4 guage wire but yet be small enough to hook to the amp. any help is greatly appreciated.
Old Dec 19, 2002 | 03:47 PM
BgJohn's Avatar
Default Re: quick question about connectors? (twolf)
This is definatly something that you're gonna have to find at an audio store. Also, check out crutchfield's selection of connectors.
Old Dec 19, 2002 | 04:00 PM
Desslok's Avatar
Default Re: quick question about connectors? (BgJohn)
I usually use a 4 ga in to 8 ga out fuse block and put it next to amps, then run 8 to the amps.
Old Dec 19, 2002 | 04:28 PM
93civdx's Avatar
Default Re: quick question about connectors? (sp)
thanks man. so you say 4 awg to 8awg will work alright. what do i do about a fuse block. forgive but i am new to this and am trying to learn. thanks.
Old Dec 19, 2002 | 04:44 PM
Desslok's Avatar
I'll post a pic of mine in alittle while.
Old Dec 24, 2002 | 09:09 AM
Feuerraeder's Avatar
fuse blocks usually have allen set (screw in) connectors
if youre only running one amp off the 4 ga and you cant find any 4 ga terminals to fit, just use 8 ga one and trim down the fibers. unless youre a 193 db big baller, it's a slim chance it will make a difference. if you'd rather not, PM me and I'll get you some soft 4 ga brass ones that can be ground down to fit just about anything.
[Modified by Feuerraeder, 1:10 PM 12/24/2002]
Spazbaboon
Audio / Security / Video
Feb 26, 2007 03:36 PM
92BluEH-3
Apr 27, 2006 01:29 PM
casmello
Oct 6, 2005 10:41 AM
jamal-188
Jul 8, 2002 06:21 PM
wu tang
May 7, 2002 07:17 PM
