Quick Question
Old Apr 25, 2002 | 05:14 PM
integradmb's Avatar
Default Quick Question
Do you think that I could fit a 10 disc changer in my gove box with some modification....i want it to be out of the way...also would the box springs be strong enough to hold the changer...i want to do something soon so I could use some suggestions or other places to put it thanks!
Old Apr 25, 2002 | 07:43 PM
t's Avatar
t
Default Re: Quick Question (integradmb)
no.
Old Apr 25, 2002 | 08:06 PM
feriocious's Avatar
Default Re: Quick Question (t)
cd changer in glove box
Old Apr 25, 2002 | 08:28 PM
integradmb's Avatar
Default Re: Quick Question (aftermidnight)
I could realy use something more constructive.
Old Apr 25, 2002 | 10:25 PM
rcurley55's Avatar
New User
depends on the changer....take somemeasurements
Old Apr 26, 2002 | 10:11 AM
incogNitto's Avatar
I can't fit my Kenwood 6-disc changer in the glove compartment. It also depends on the angle it will leave your changer at when mounted. With a glove compartment that is in the dash and the only thing that moves is the door, you would have some luck. On an Integra the glove box actually flips down, so when you close it, everything in there tilts (I'm sure you knew that). My changer can be mounted at 0, 45, and 90 degrees, and I think the box probably closes to like 60 or something, so the angle would be bad for the changer to rest at when playing. Consider other options. You may be able to cut the top of the glove box where it slopes and you can't push the changer in more, but that's a one-way mod that you can't really fix.
Old Apr 26, 2002 | 10:57 PM
t's Avatar
t
Default Re: Quick Question (incogNitto)
The Integra glove is too small for any changer to fit. I have seen some people hack up the glove box to try to fit a head unit, in the end the head unit went in its respective location + now they didnt have a glove box anymore.
Bobnotch
Nov 17, 2017 06:12 PM
atarasi
Jan 31, 2008 07:29 PM
integra_dude
Audio / Security / Video
Jun 26, 2004 12:42 AM
