quick ohm's question
Old May 27, 2003 | 05:28 PM
Ludeboi's Avatar
Default quick ohm's question
if the lowest an amp can go is 2 ohms, is it a good idea to run it at 1.5?
Old May 27, 2003 | 05:44 PM
vteg's Avatar
New User
Default Re: quick ohm's question (Ludeboi)
Nope.
Old May 27, 2003 | 06:42 PM
Bigphlip's Avatar
You can run it at 1.5 but it will overheat after a while. How are you getting 1.5 ohms? You should make sure that 1.5 is the impedence that you are running because many people get confused over ohm's law.
Old May 27, 2003 | 06:59 PM
nsxxtreme's Avatar
How did you determine it was 2 ohm stable? vteg pretty much summed it up though.
Old May 27, 2003 | 07:12 PM
Synergy001's Avatar
Default Re: quick ohm's question (nsxxtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">How did you determine it was 2 ohm stable? vteg pretty much summed it up though.</TD></TR></TABLE>
he probably looked it up in the manual or some sort
Old May 27, 2003 | 07:43 PM
Ludeboi's Avatar
i was looking at getting the memphis 500d amp, and i got 1.5 ohms by running 2 w6's parallel
Old May 27, 2003 | 08:37 PM
nsxxtreme's Avatar
I have gotten away with doing what you are trying to do it just depends on the amp. I know nothing about memphis. I would just try it and pay close attention to how hot it gets. If it gets really hot you will shorten the life of the transistors inside. You may also trip the built in short circuit protection because the load may be to low. I have ran 1/2 ohm to Autotek Mean machines before no sweat.
You could also run your speakers in series then parallel for a 6 ohm load but this defeats the purpose of what you are trying to do.
Old May 29, 2003 | 01:21 PM
n0 iNTegRiTY's Avatar
Default Re: quick ohm's question (Bigphlip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bigphlip &raquo;</TD></TR><TR><TD CLASS="quote">because many people get confused over ohm's law.</TD></TR></TABLE>
Definitely. Ohms are probably one of the most difficult concepts ive had to understand
Old May 29, 2003 | 01:51 PM
Torridcivic's Avatar
Default Re: quick ohm's question (RAF LTD. 2)
Don't get me as stupid, But Could someone sum up ohms law. What causes certain subs and amps to be certain ohms? I never really got the series/parallel idea, I know the increase or decrease the ohms load, right? How does that work?
Old May 29, 2003 | 02:10 PM
t0p_sh0tta's Avatar
Default Re: quick ohm's question (Torridcivic)
Ohms...
Old May 29, 2003 | 02:17 PM
nsxxtreme's Avatar
All ohms law does is express voltage as a function of current I=V/R The units of the impedence are in ohms named after Georg Simon Ohm.
I think for what you are trying to do you would more follow Kirchoffs law.
For series impedence you just add them 4ohm plus 4ohm = 8ohm
For parallel impedence you use this equation 1/(1/4ohm + 1/4ohm)=2ohms
If you have more Impedences you keep usining the same equation just add more impedences in the denominator. 1/(1/4ohm + 1/4ohm + 1/4ohm +ect) = 1.33Ohms
Many short cuts have been made here to keep it simple
Old May 30, 2003 | 10:45 PM
uhhhhhh... i think I might be able to make sense of that if it weren't 3 AM right now.
Built B16A
Audio / Security / Video
Jul 30, 2011 04:32 PM
GetawayInMoscow
Jan 22, 2005 08:16 AM
01ITR#700
10
Jan 11, 2005 08:31 AM
Odessa
Aug 17, 2004 09:00 PM
ilikemyaccord
Jul 21, 2003 06:02 PM
