quick help needed...
Old Mar 9, 2003 | 11:17 PM
armharm's Avatar
Default quick help needed...
ok guys so my mom's mazda protege's battery died and i had to jumpstart it.. well now the alarm is fucked up.. the LED is solid on and when i press the button on the remote it doesnt do anything.. i have to lock/unlock it manually now.. does anyone kno of a quick fix or do i need to get it checked out by a pro? i am fairly competent when it comes to electronics and cars so lemme kno what to do.. TIA!
Old Mar 10, 2003 | 04:15 AM
Bigjon
Guest
Posts: n/a
Default Re: quick help needed... (armharm)
Try disconnecting the alarm from power by taking out the fuse for a little bit. Maybe it will reset it or something.
Old Mar 10, 2003 | 06:07 AM
civicrtype's Avatar
if the LED is solid then the alarm is in Valet Mode, make sure you didn't accidentally hit the valet switch. If not just take it out of valet mode. Each alarm is different so look at the user manual that came with your alarm.
Old Mar 10, 2003 | 06:27 AM
nOOber's Avatar
Default Re: quick help needed... (civicrtype)
thats a pretty crappy alarm if it goes in to valet when you unplug the battery...
what kind is it?
Old Mar 10, 2003 | 07:58 AM
koco's Avatar
You probably need to turn the ignition on and press the valet switch for a couple of seconds to take it out of valet mode.
I agree, it's crap or hooked up wrong if it goes into valet by disconnecting the battery.
SuckItEasy
Audio / Security / Video
May 4, 2012 05:14 PM
lickety_britches
Nov 27, 2008 09:07 PM
sagron69
Oct 23, 2005 07:09 PM
kim97lx
Jul 27, 2004 09:56 AM
I Gotta Question
Jan 26, 2004 07:33 AM
