Question about dynamat installation
Old Jul 31, 2006 | 05:23 PM
eL's Avatar
eL
Default Question about dynamat installation
Hey,
I just bought a bulk pack of dynamat to put in my 06 Civic to quiet down the noise/rattles in the rear deck and trunk. I was wondering if I really need a "roller" or any other special tools to install this stuff or can I just peel and press it down with my hands.
Thanks
Old Jul 31, 2006 | 06:24 PM
B18C_EJ8's Avatar
You don't 'need' a roller, but it makes it tons easier...
Old Jul 31, 2006 | 07:04 PM
thejacka's Avatar
yeah it really does.. cut my installation time in half literally, the edges of the roller are very useful in corners of the car. saves you from cuts sometimes too.
Old Jul 31, 2006 | 07:53 PM
hb420's Avatar
Use the handle of a paint brush for the corners if you don't have a roller. They are a waste of money
Old Aug 1, 2006 | 09:35 AM
tacticalcustoms's Avatar
Default Re: (hb420)
also trying using a blow dryer to heat up the sticky glue. it helps make it stick alot easier and makes it alot harder to fall off if the glue is old....
Old Aug 1, 2006 | 12:02 PM
LudemanDan's Avatar
Clean the area first, with rubbing alcohol or something similar. The more mat is actually sticking, the more it's doing it's job.
If you're doing a large area, a roller will spare fatigue on your hands tremendously.
Thank you for actually spelling Dynamat correctly. You even did it twice. You are in the top 5th percentile of intelligence here on h-t.
Old Aug 1, 2006 | 03:19 PM
8520's Avatar
Default Re: (LudemanDan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudemanDan &raquo;</TD></TR><TR><TD CLASS="quote">
Thank you for actually spelling Dynamat correctly. You even did it twice. You are in the top 5th percentile of intelligence here on h-t. </TD></TR></TABLE>
..... how else would you spell it? ..?
Old Aug 1, 2006 | 06:31 PM
LudemanDan's Avatar
A lot of people use an O in the middle.
Old Aug 1, 2006 | 09:27 PM
CooBlueDAB's Avatar
moreso than the roller... "roll" it on, start at one edge and slowly press it from one side to the other.
Old Aug 2, 2006 | 02:04 AM
dmacaalay's Avatar
Default Re: Question about dynamat installation (eL)
dont really need a blow dryer with the new dynamat.. and i just used the back end of a a screwdriver to hit those corners.. worked out real good.. be careful using the hands.. that dynamat cuts like crazy.. stings much worse than your regular paper cuts.. haha
Old Aug 2, 2006 | 02:38 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Question about dynamat installation (dmacaalay)
Hell, a nice hot day. Lay it out in the sun for about 15-20 min.-its was 110 when we did it. went on like a champ. Yea watch those fingers, cuts are a mf and they sting like no other
d15b7inEF
10
Jun 12, 2011 12:48 PM
beoy9
Feb 12, 2007 09:45 AM
DIP_SET FoReVr
Feb 9, 2004 11:45 AM
216.226.142.95:27016
Jan 6, 2004 09:54 PM
