Q's on ek/ef sound systems.
Old Sep 27, 2008 | 02:32 PM
SuM Honda's Avatar
Default Q's on ek/ef sound systems.
Okay we have an ek sedan and ef sedan, ek has stock speakers and a cheap after market radio, nothing else, ef has after market radio and nicer aftermarket speakers BUT for some reason it has no bass what so ever...The ek on the other hand has a ton of bass with its cheap oem speakers...Can anyone explain this to me? Does the ek have something Im not mentioning? Neither cars have subs or anything else other than speakers THAT I KNOW OF...As far as the sound goes...the ef sounds alot better, but any song that requires any bass just sounds weird.
Thanks!
Old Sep 27, 2008 | 04:13 PM
fcm's Avatar
fcm
Old Fart
Default Re: Q's on ek/ef sound systems. (SuM Honda)
Check the ef speaker wiring, the speakers may be wired out of phase, you can check for phasing by using the HUs balance control to balance the system all the way to the left or right, if bass response is better when only the left or right side speaker(s) are on then when both are on, [left and right] then the speakers are wired out of phase, remove one speaker and switch the speaker leads, it does not matter if you rewire the left speaker or the right speaker. 94
Rhonda14
Suspension & Brakes
Apr 5, 2011 11:11 AM
candyman206
Jan 13, 2010 07:14 PM
B16EJ
Mar 19, 2005 01:34 PM
eg360B
May 25, 2004 11:52 AM
