Pulling up carpet... how?
Old Jul 19, 2001 | 04:07 AM
kg's Avatar
kg
Default Pulling up carpet... how?
okay, so perhaps i am just dense, but i was trying to figure out what i would need to pull up the carpet and replace it properly when doing a stereo install. How hard is it to make it look right again?
Old Jul 19, 2001 | 04:27 PM
redblues's Avatar
New User
Default Re: Pulling up carpet... how? (kg)
Normally you just find the edge of the carpet and work from there. In practically all cars I've done there are holes in the carpet under the center console. The carpet ends right under the rear seat. And the side edges of the carpet can easily be lifted by prying up the threshhold plate (running along the bottom door edge). Most of the time the carpeting is held in with snaps. Some cars use good quality snaps, some do not and you will end up breaking them.
Personally my favorite tool used to pry snaps and other press fitted objects is a mini pry bar used to remove nails. Wrap the bar with electrical tape so you don't scratch things.
Carpet isn't too hard to work with. Just don't run thick wires like amp power wires or maybe RCA's under the center console since they will raise the carpeting on the rear floor hump. In fact I wouldn't run any wires through the center console except the amp turn on lead.
Replacing the carpet is easier than putting in the seats. Nuff said.
fragmare
Jun 24, 2013 02:01 PM
airikkCRX
May 8, 2010 01:11 PM
larryd
Honda Civic (2006 - 2015)
May 19, 2006 10:22 AM
KOREAN
Jul 7, 2005 06:44 PM
ActiveAero
Apr 9, 2002 02:35 PM
