pullies
Old Jan 2, 2003 | 12:15 PM
NCSTIdriver's Avatar
Default pullies
I just got a decent sub setup which is about 450 watts. I Have a capacitor. I am just wondering would i need anything else if i put AEM pullies on my car.
Old Jan 2, 2003 | 12:58 PM
vteg's Avatar
New User
Default Re: pullies (NCH22driver)
Is that 450 rms? What other amps do you have?
Old Jan 2, 2003 | 03:06 PM
Default Re: pullies (vteg)
sorry its a JL audio 500-1 amp. powering JL W6 v2 12. I only have one amp
Old Jan 2, 2003 | 05:20 PM
vteg's Avatar
New User
Personally I think you are fine as long as you don't sit idle too long Have you noticed any problems?
Old Jan 3, 2003 | 08:51 AM
92sleepR's Avatar
New User
You know of course that the AEM pullies will UNDER-drive your alt, giving you less amperage to work with? I would recommend not getting them if you plan on going really loud although with 450 watts you are probably ok. I also recommend upgrading the main wire from the alt to the fuse box and from the fuse box to the battery to 4 gauge and add a 4 gauge ground wire from the alternator support bracket to the grounding point for the battery negative cable.
Mike
Old Jan 14, 2003 | 09:17 AM
Default Re: pullies (92sleepR)
I have the pullies on now. I just needed to find the belt that will work with the JRSC. haven't noticed any problems yet when its turned up normally. When i crank it my interior light and headlights will dim a little though . Im going to pick up a capacitor next week. any suggestions on brand names? JL stuff sounds so good
[Modified by NCH22driver, 6:19 PM 1/14/2003]
Old Jan 14, 2003 | 10:07 AM
nsxxtreme's Avatar
What are the pullies going on? Hopefully you will not be replacing the harmonic balancer.
chillerice
Audio / Security / Video
12
Feb 9, 2013 07:32 PM
///Nick
Aug 13, 2011 04:06 PM
shawn69
Jan 21, 2007 11:47 AM
doublethink
Oct 19, 2005 08:40 PM
TheKamikazeSquirrel
Jul 7, 2004 09:45 AM
