Problems with my setup..please help..
Old Dec 28, 2002 | 11:56 PM
JDEM1's Avatar
Default Problems with my setup..please help..
i have a precision power pcx2125 amp, its 500watts max, and i bought a polk momo 12 inch subwoofer last year and it blew, got another one and it blew.. the polk momo is 1000watt max, 500rms, whats going on here?.. they didnt blow right away, they worked fine, but just decided to blow one day.. same on both... and i got the right box for it... q-logic .88 dimension box?.. thats what they recommended.. anyhow.. what do you guys think?.. get another polk momo? or what sub do you recommend for my enclosure+amp?.. i realllllllly need some info on why my subs have been blowing.. TIA
[Modified by G_Force_Si, 8:57 AM 12/29/2002]
Old Dec 29, 2002 | 12:02 AM
stockITR
Guest
Posts: n/a
Default Re: Problems with my setup..please help.. (G_Force_Si)
wuts the ohm of the subs? check all ur wires and make sure none of them touch each other. i wouldnt really know unless i c it. second, i ran a pcx 2125 and it sucks. i was using them on 2 diamond audio m6's 800 watt rms. i was under powering them and the piece of chit amp blew. im now running arc audio 1500dr, and i love the amp, it is honestly the chit
Old Dec 29, 2002 | 12:15 AM
JDEM1's Avatar
Default Re: Problems with my setup..please help.. (stockITR)
i believe the sub is 4ohm, is that right to match it with the pcx2125?.. sorry im not much of a sound system expert.. anyhow, yeah the amp would be weak if it had to power 2 800rms subs because it is 500max alone, i use the single amp to power a single sub which worked out great and sounded clean, but i just want to know what went wrong, thanks for the input
Old Dec 29, 2002 | 12:21 AM
phoenixR
Guest
Posts: n/a
i would have to look at it. im in pasadena 626 which isnt too far from u. if u wanna meet up and let me take a look, let me know.
EDIT: hey, im at 60%. 99% is very good
[Modified by phoenixR, 1:22 AM 12/29/2002]
Old Dec 29, 2002 | 08:24 PM
JDEM1's Avatar
Default Re: Problems with my setup..please help.. (phoenixR)
cool, i will find out a good time, but for now, do you think it would be possible to fix the sub?..or any other ideas?.. .. i would also still like to know how compatible my setup was... thanks
Hanmin
Audio / Security / Video
Jun 3, 2009 10:36 PM
MASTERJDM
Mar 14, 2007 10:24 PM
97VtecIN
Feb 2, 2005 04:57 PM
AlphaKennyWun
10
Feb 7, 2002 02:41 AM
