Prelude lock wiring
Anyone know an easy place to find the door lock and unlock wires in a 95 Prelude. I read that they are blk/red and blk/wht respectively and that they can be found near the fuse block in an 8 pin connector, but I can't seem to locate them.
Also, anyone have any suggestions for where to mount a siren? I was thinking of looking in the driver wheel well, behind the fender liner since there isn't a lot of room under the hood. I don't really want to remove the bumper to install it inside there either.
thanks
Bryan
thanks
Bryan
Bryan,
The Power Lock should be black/white and the unlock should be black/red. You should find them in the passenger side kick panel in a 10pin harness. You might be able to find them in the factory security plug to the left of the steering column. The plug should be grey.
Good luck
Good luck
DA1
Audio / Security / Video
Jan 12, 2006 11:44 PM
