Power Window Motor not Working
Old Oct 5, 2010 | 03:29 PM
Reme's Avatar
Default Power Window Motor not Working
My passenger side power window motor stopped working. I changed the motor today hooked it up for a test and nothing. It won't go up or down from the passenger side and driver's side controls. I took the old motor and hooked it up directly to the battery and the gear started moving. I checked the fuse and it's still good. Anyone have a clue what the problem is?
Old Oct 5, 2010 | 05:18 PM
joeymc13's Avatar
Default Re: Power Window Motor not Working
Y,M, & M? we're gonna have to trace the pwr window circuit...
Old Oct 5, 2010 | 06:57 PM
Reme's Avatar
How should I do that?
Old Oct 5, 2010 | 07:10 PM
joeymc13's Avatar
Just start off with hookin me up with the Year, Make, and Model of the car these motors are intended for...
Old Oct 5, 2010 | 07:22 PM
Reme's Avatar
1998 Honda Prelude
Old Oct 6, 2010 | 03:59 PM
joeymc13's Avatar
Let's start with the easy stuff... the window switch is plugged in? (dumb ?, I know, but I've seen something like that overlooked before)
Underdash fuse box, fuse #16, 20amp, is this fuse good?
Do you get 12v on each side of that fuse with ignition on?
Old Oct 6, 2010 | 04:08 PM
joeymc13's Avatar
at your passenger door power window switch, there should be a blue wire w/black stripe. Does this wire have 12v with ignition on?
USA
Oct 2, 2021 03:13 PM
kptrk06
Honda Civic (2001 - 2005)
Jun 29, 2014 09:26 PM
Syke Fu
Oct 7, 2011 10:41 AM
Donkeeyyy
May 29, 2011 08:10 AM
Guineapig
Sep 9, 2007 06:29 PM
