power door locks
Old Apr 28, 2012 | 06:20 AM
lilboxx's Avatar
Default power door locks
i have a 92 honda civic cx and i was just wondering what all would i have to do to switch my car from manual door locks to power? the only reason i am doing it is so i can take advantage of the keyless entry with my alarm system. is it possible to just buy a universal actuator and just hook that straight up to the alarm system? thanks
Old Apr 28, 2012 | 05:59 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: power door locks
2 relays and 2 dool lock acutrators and your good
Old Apr 28, 2012 | 07:27 PM
lilboxx's Avatar
what kind of relays do i need? and how would i wire them up im not to familiar with relays lol
Old Apr 28, 2012 | 08:51 PM
ninjaturtleEG's Avatar
For my alarm system, it has a built in relay in the brain for the central control lock plug in so I didnt have to wire in relays but if you did i think they'd be stdp relays. Check in your alarm's manual to see if yours already has a built in relay.
Old Apr 28, 2012 | 09:15 PM
lilboxx's Avatar
Ill check that in the morning i know the manual for it said it has positive and negative outputs for power locks
Old May 2, 2012 | 11:14 AM
fcm's Avatar
fcm
Old Fart
You will need 2 SPDT relays wired like this...
Courtesy of http://www.the12volt.com/relays/relays.asp you should read this.
Or you can get a central door lock system like the Audiovox ProPDL25... http://www.crutchfield.com/p_220PRPD...25.html?tp=154
Then you do not need the relays and your manual door lock switch becomes a power door lock switch. 94
droopy128
Sep 22, 2018 05:47 AM
si90rex
Audio / Security / Video
Nov 18, 2008 04:55 AM
AARON RLH
Sep 16, 2008 02:15 PM
muhaMan
Apr 15, 2007 04:12 PM
slowturtle
Apr 29, 2005 06:59 AM
