Power Door lock help!
Old Sep 20, 2011 | 11:17 PM
Jdmglenn's Avatar
Default Power Door lock help!
I have a 1998 civic ex sedan. Out of no where the power door locks no longer work via. switch, key, viper alarm.
i switched out the actuator, door lock module (blue box in drivers door) and checked fuse 51 which is for sunroof and locks but my sunroof works fine.
What else could it be? is there a relay somewhere i dont know about? thanks in advance
Old Sep 21, 2011 | 06:02 PM
fcm's Avatar
fcm
Old Fart
Default Re: Power Door lock help!
There is no relay, check the white/green lead going to "Power Door Lock Control Unit" for power, should be 12V+ at all times, [fuse 51], if there is no power on the white/green, check for a break in the white/green in the drivers door jamb boot.
If white/green has power check for a groun on the black lead at the "PDLCU", if no ground, again check for break in door jamb boot. 94
Old Sep 21, 2011 | 07:13 PM
Jdmglenn's Avatar
ok i will check first thing in the morning since i have the whole door apart now lol. Thanks again FCM
Jdmglenn's Avatar
oh and the pdlcu isnt clicking at all which means no power correct?
Old Sep 21, 2011 | 07:34 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Well we won't know untill you test power to the unit. There has to be power and ground to it.
Old Sep 22, 2011 | 07:10 AM
Jdmglenn's Avatar
Ok so the White/Green wire at the module is dead. I think im gonna try to run my own power wires from the fusebox through the door jamb harness to the module
Old Sep 22, 2011 | 07:45 AM
fcm's Avatar
fcm
Old Fart
Why not just repair the white/green lead, it is most likely broken in the door jamb boot, it is a common problem. [broken leads in drivers door jamb boot] on just about any car, the older the car the more common the problem.94
Old Sep 22, 2011 | 08:27 AM
Jdmglenn's Avatar
I was lazy to pulll off the fender but ill do it the proper way now, ill let you know how it goes
Old Sep 22, 2011 | 11:20 AM
fcm's Avatar
fcm
Old Fart
You should not need to pull the fender, unplug the door harness and pull boot into the door and out the speaker opening, slide boot down the wire harness and make repairs.
If your door harness plug is not on the "A" pillar and is on the door, unplug it and pull it into the car and make the repairs. 94
bpenner
Honda Civic (2001 - 2005)
Jun 25, 2018 03:53 PM
viprcr1
Mar 14, 2007 08:59 AM
union122
Sep 5, 2006 04:15 AM
vwtuner
Apr 27, 2006 07:26 PM
