power antenna needs power.
who ever hooked up the player in my car didn't use a wire harness and spliced all the wires correct but didn't wire up the power antenna. the wire is white/yellow i think.
what wire can i splice it to so that it works good without messing up anything. I thought of splicing it into the remote wire that turns on the amp. will that work?
thanks.
thanks.
If you can't get your hands on a wiring digram then I would go and buy a harness from a stero shop and use that to tell you what wire you need to connect. On the harness it will be the solid blue wire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilduck »</TD></TR><TR><TD CLASS="quote">If you can't get your hands on a wiring digram then I would go and buy a harness from a stero shop and use that to tell you what wire you need to connect. On the harness it will be the solid blue wire.</TD></TR></TABLE>
Most head decks will have a seperate wire for the remote antenna that will only put it up when the radio is on. If your deck doesn't have one of those then use the amp remote wire but then the antenna will be up even when you are listening to a CD.
nocturnal EG
Audio / Security / Video
16
Nov 3, 2006 08:04 AM
