pics of custom box setups
Old Nov 16, 2002 | 07:18 PM
SpoonFedHatch's Avatar
Default pics of custom box setups
i am currently building a custom flush-trunk mounted box with two 10" subs and amp....my only problem is that the subs are sealed and i will have to seal the box underneath.....anyone got pics of how you created a box underneath the main trunk cover to fit into the spare wheelwell....YES i did a search and turned up nothing...thanks in advance...ps....92 civic hatch
Old Nov 16, 2002 | 09:53 PM
b18bEG's Avatar
Default Re: pics of custom box setups (SpoonFedHatch)
check out the alpine site
http://www.alpine1.com
it shows ther rsx install, and that might give u an idea how to do it , somewaht
Old Nov 17, 2002 | 06:17 AM
JDubya's Avatar
i did the same thing, use fiberglass. how i did it was: build a frame around the spare tire well using MDF. i also put a divider goin down the well to seperate the two subs. once the frame is done, lay a bunch of tin foil on the well under the frame. now, just use the fiberglass to make a bottom for the frame. then you can just screw the top piece on that the subs are in. u can get the fiberglass resin and mat from wal mart or home depot. i have pics documenting my set up, from start to finish (almost finished, just need to add finishing touches like putting on the fans for my plexiglass covered amp box that sits flush w/the false floor, getting the plexiglass, and putting in the red LEDs all inside that box.) but the pix are all on my digi. and i lost it if i ever find it i'll post up the pix. if you have any more questions feel free to ask
[Modified by Hybrid Teg98, 3:31 PM 11/17/2002]
Old Nov 17, 2002 | 06:19 PM
Default Re: pics of custom box setups (Hybrid Teg98)
sweeeeet....thanks for replies--much apprecieted
Old Nov 17, 2002 | 06:47 PM
MachAF's Avatar
http://www.geocities.com/MotorCity/7165/how_to_1.htm
check that out. Fiberglasses my tire well in my integra... pain in the ***.
JDM_SOHC
Audio / Security / Video
Jul 21, 2012 01:03 PM
Colin
Oct 1, 2006 10:08 PM
Colin
Sep 28, 2006 07:31 PM
integradmb
Apr 16, 2002 07:40 PM
