phoenix gold tantrum sub!!!!!!
Old Jul 6, 2004 | 07:23 PM
bassisliffe's Avatar
Default phoenix gold tantrum sub!!!!!!
im a pg fan for life! just bought a tantrum X 12 inch and giving it 750 rms and its GREAT! sq is there it hits the llows everything a man could need!
ill post pics when i hook up the lights
Old Jul 6, 2004 | 08:19 PM
Default Re: phoenix gold tantrum sub!!!!!! (bassisliffe)
how do i hook up the lights? just to the coils?
was thinking i could hook them and have them come on by switch on the dash
Old Jul 7, 2004 | 04:41 PM
tried it in a ported box today
i like it, but worried about the 750 rms even though the gain is hardly cracked on my amp!
Old Jul 7, 2004 | 07:30 PM
lol, it fried
Old Jul 7, 2004 | 11:20 PM
hybridzOr's Avatar
damn man...
sounddomain.com
do you even have a honda... hahahaha
Old Jul 8, 2004 | 05:19 AM
Default Re: phoenix gold tantrum sub!!!!!! (Hybrid Racer.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Racer. &raquo;</TD></TR><TR><TD CLASS="quote">damn man...
sounddomain.com
do you even have a honda... hahahaha</TD></TR></TABLE>
i was under the impression that alot of people on here didnt drive a honda
Old Jul 8, 2004 | 05:25 AM
spark plugs.
Guest
Posts: n/a
you blew the sub already?! man o man. you need to start takin' your time with this ****. from the looks of the wiring in your pics, you're not exactly a perfectionist.
aren't the tantrums 300-400 watt subs anyway?
Old Jul 8, 2004 | 09:07 PM
nsxxtreme's Avatar
In this section of the forum we don't care if you drive a Honda, many don't.
How did you blow your sub? If it was an electrical failure more than likely you over powered it.
Old Jul 9, 2004 | 12:08 AM
Default Re: phoenix gold tantrum sub!!!!!! (spark plugs.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spark plugs. &raquo;</TD></TR><TR><TD CLASS="quote">you blew the sub already?! man o man. you need to start takin' your time with this ****. from the looks of the wiring in your pics, you're not exactly a perfectionist.
aren't the tantrums 300-400 watt subs anyway?</TD></TR></TABLE>
ok let me explain, the sub was broken in at 8ohms for hours, at least 6
i had the gain on the amp down, the gain ov the x-over down and the bass on the h/u down
but i fucked up when the jay-z song plated
'if you fellin like a pimp ***** go on brush you shoulders off'
turned up the crossover and the 'bass boost' on it, then i turned up the sub gain on the h/u and it was knocking hard for a few hours until it fried
but its ok i caried it to be repaired today getting it back soon, its 350 rms i was giving it 750, maybe ill just wire it at 8ohms
Old Jul 9, 2004 | 12:21 AM
hybridzOr's Avatar
750 pssshh
&lt;who will push 2 10's with like 1500 watts.. rms
Old Jul 9, 2004 | 03:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Racer. &raquo;</TD></TR><TR><TD CLASS="quote">750 pssshh
&lt;who will push 2 10's with like 1500 watts.. rms</TD></TR></TABLE>
hehe
sub is fixed and ported and at 8ohm draw on the amp hould be seeing about 300 or 400 i dunno no specs for the directed 1100D @8ohms!?
Old Jul 9, 2004 | 04:23 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassisliffe &raquo;</TD></TR><TR><TD CLASS="quote">
hehe
sub is fixed and ported and at 8ohm draw on the amp hould be seeing about 300 or 400 i dunno no specs for the directed 1100D @8ohms!? </TD></TR></TABLE>
It's class D and I bet 8 ohms is out of it's design parameters. If sound quality is not that important I would guess it's 60% or so of the 4 ohm power.
Old Jul 9, 2004 | 04:29 PM
Default Re: phoenix gold tantrum sub!!!!!! (Jim Truett)
so you are saying the sq wont be great?
its what 440 at 4ohms, so 60% of that should be good for a 350rms sub right?
i didn't do mathematics in high school
Old Jul 9, 2004 | 06:38 PM
Jim Truett's Avatar
It's not pure math involved. It has to do with the fact that with a class D amp the distortion can increase greatlty if the amp is operated with a higher impedance load than it is designed for. It all has to do with the switching frequency of the amp. I do not have any directed amps to test, so you will have to determine if the bass sounds mushy with it at 8 ohms. Personally I wouldn't run a woofer I cared about, wired at 8 ohms, on an amp that was designed to run at 4 ohms and less.
Old Jul 9, 2004 | 06:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">Personally I wouldn't run a woofer I cared about, wired at 8 ohms, on an amp that was designed to run at 4 ohms and less.</TD></TR></TABLE>
i think you get the point i got it for about 50 bucks i care about it as much as i care about a grain of sand
well since the 8ohms is iffy, im going to wire it back to 2ohms!
Old Jul 10, 2004 | 12:11 PM
FatJoe's Avatar
why dont you just save ur money and get a setup that works....?????????
Old Jul 10, 2004 | 02:44 PM
Default Re: phoenix gold tantrum sub!!!!!! (FatJoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FatJoe &raquo;</TD></TR><TR><TD CLASS="quote">why dont you just save ur money and get a setup that works....?????????</TD></TR></TABLE>
all of my past systems have worked
what do you mean? define works?
if you are asking me why i dont save for a w7 its because i dont want something too expensive in my car
and i like to change subs just to say ive used so and so
i switched it from 8ohms back to 2ohms cause it sounded horrible
like the sub was in muddy water
oh yeah i put it back in the sealked box today, sounds better than ported, think ill sell it soon and go back to comp vrs for a while
Old Jul 10, 2004 | 03:12 PM
FatJoe's Avatar
so basically you dont get subs because you want a full range system in ur car, you want to be able to tell people youve used this sub and that... i wonder if clubsi.com has an audio section...
i mean i guess do what you want, its ur money and ur time... i just think its weird that you go from this and that so often. i figure most people just want to get something in their car that will sound good or loud or even both, and then settle in with it and enjoy it. if you love changing subs so much, you really ought to get a job doin this sort of thing and test it on other peoples cars. just a thought.
Old Jul 10, 2004 | 05:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FatJoe &raquo;</TD></TR><TR><TD CLASS="quote"> i figure most people just want to get something in their car that will sound good or loud or even both, and then settle in with it and enjoy it.</TD></TR></TABLE>
not me, yuk, im in this for fun and experimenting, come on how many people can have the same sub/amp set up for long much less forever
i can't
but that might be because i work in my jeep all day long
joshcuhz
Oct 29, 2008 07:19 AM
3vilMonkey!
Jan 1, 2007 05:28 PM
m R g S r
Mar 8, 2005 07:25 PM
jkeno112
Dec 15, 2004 12:54 PM
SlowWhiteEvo
Feb 18, 2004 08:23 AM
