pedal sequence code before starting car?
i remember reading somewhere that you can get something where you have to do some kind of pedal pressing sequence before you start your car.
for example, brake, brake, gas, clutch. then it will start. if you don't do it, it won't start.
anyone have any information this? what it's called? i forgot.. and any idea on what it costs would be great. i figure it may be a great security feature for the right price. thanks.
Never heard of it.
My unlces jeep is basicly started by 3 switches. Put each one in the right spot, and it will start. If you can figure out to do it, it would work quite well.
Basicly just like a kill switch, but instead of 1, you have 3 or whatever switches to complete the circut.
Never heard of it.
If you're interested I can try to find a link for you.
Never heard of it.
sure. sounds like a good read
Never heard of it.
Use the key pad start security. Wired the pedals to any number.
For example clutch(1) brake(2) gas(3)
Code: 3121 = gas clutch brake clutch
The differences with this jeep is it hangs out in the garage, whatched by 3 big *** dogs.
It's rarely out of his sight anyways.
If you wanted to do this, you would need to be a little more careful where you put the swithces.
hahaha
yeah i figured.
and yeah definitely. wouldn't want someone to be able to complete the circuit easily. i've thought of some good places for a kill switch.
Switches are not hidden, they are in plain sight.
my old si had kill switch hidden in the shift boot. IDK if that's a common place or what... seemed like a good place at the time. However my city has like 1-2 cars stolen a year, so not really a big deal here.
i'm not real good with ECUs. i googled neptune rtp. so would i have to buy their ECU and then get it tuned and everything? or is it something that goes into the ECU you already have? i have a stock ECU right now so it may be a good time to get a chipped/tuned one.
This is currently available with Neptune RTP / Moates Demon:
http://www.hamotorsports.com/neptune-rtp-license.html
"* Anti-Theft feature requires inputs or a code to be entered with TPS and Brake pedal. Also has a valet/fallback mode with adjustable rev limit."
The anti-theft works perfect. You just select whatever sequence of throttle and brake presses you can think of (and remember this code of course). The ECU will not allow the car to start unless you input the code.
I used to run this with the valet mode off ( won't let the car start without the correct code whatsoever ), but found it somewhat unsafe. For those of us with wild builds/ unstable idle if you kill it while driving you may be stuck in an interesection turning ign off, back on, entering code, etc.. while traffic is running you over lol..
what's socketing an ECU involve? something a tuner would do or i can do? so you're saying i can keep my current OEM ECU?
Chipping it. You can do it your self, however unles you have experience doing this sort of work I reccomend haveing a shop do it for you.
You will also need to get it dyno tuned.
You will also need the Moates Demon to use with Neptune... another easier alternative is to just get the complete ECU package with the Demon already socketed into the ECU and the registered Neptune License:
http://www.hamotorsports.com/neptune-rtp-package.html
You will then have this dyno tuned at your local shop..
damn $550 + shipping? is all that really worth it? couldn't i just buy the Moates Demon and use my current ecu and still get the same benefits? just without the clear cover on the ECU? haha
http://www.hamotorsports.com/demon-neptune-package.html
You will then install this into a standard socketed ECU..
As you will see, the full package just makes it easy for you to get up and running
249 for Demon, plus 150 for License, plus 150 for ECU = $549.00 (clear cover is free)
