Oertheating Amp
Old May 20, 2007 | 09:42 AM
eskimo10's Avatar
Default Oertheating Amp
I have an Audiobahn 1600 Watt Amp and two 12" Audiobahn Sub woofers. The amp is wired with 4gauge power (with a 60 amp fuse) and ground wire, wired through a capacitor. Now the problem with all this is that when i run it, which normally is about half power on the cd deck and 2/3-3/4 power on the amp itself, it will only work for about half an hour to 40 minutes and then cut out b/c it over heats. I've check all my connections and they're solid, no rusting or loose connections so I know thats not why it overheats. This is a picture of my setup at the moment
http://i22.photobucket.com/alb...5.jpg
I was wondering if anybody can think of any reasons why it would over heat after such a short period of use, or even over heat at all. Thanks for your help!
Old May 20, 2007 | 10:10 AM
ARMED's Avatar
how did you wire your subs???
is it a dual 2 or dual 4???
Old May 20, 2007 | 02:37 PM
eskimo10's Avatar
I think they're wired in a series, I didn't wire them though, the guy I bought the car had them wired before I picked it up. What do you mean by dual 2 or dual 4?
Old May 20, 2007 | 07:53 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (eskimo10)
^^^^^ There the problem right there. Plus your link does not work
Old May 21, 2007 | 04:45 PM
eskimo10's Avatar
What's my problem? The fact that they're wired in series? Should it be parallel?
Old May 21, 2007 | 04:47 PM
eskimo10's Avatar
There.
Old May 21, 2007 | 05:20 PM
B18C_EJ8's Avatar
Wow, that looks like total ***....
But anyways... You really need to determine how they're wired up... Without knowing the ohm load on the amp, we can't troubleshoot any further...
Old May 21, 2007 | 05:22 PM
eskimo10's Avatar
don't worry bro it's not done. probably will be ripped out and rebuilt anyway.
how the heck do I figure out the ohm load on the amp?
Old May 21, 2007 | 05:56 PM
B18C_EJ8's Avatar
You could start by telling us exactly how the subs are wired...
Or, you could do it the easy way and determine the load with a meter...
Old May 21, 2007 | 06:04 PM
eskimo10's Avatar
well I believe they are in series.
http://www.rockfordfosgate.com...imp=4
as in this. I also am quite positive the subs are 3.3 ohms each if that matters.
Old May 21, 2007 | 06:08 PM
eskimo10's Avatar
sorry forgot to mention they are wired like the first wiring option
Old May 21, 2007 | 06:45 PM
eskimo10's Avatar
never mind i got it figured out
Old May 22, 2007 | 01:36 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eskimo10 &raquo;</TD></TR><TR><TD CLASS="quote">http://i22.photobucket.com/alb...5.jpg
There.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eskimo10 &raquo;</TD></TR><TR><TD CLASS="quote">never mind i got it figured out</TD></TR></TABLE>
Did you also figured out that your subs are not a free air sub. Let alone that the front and the back of the speaker are not sealed from each other well. Which is causing cancellation and a lack of bass. And inturned your probably cranking the radio up to try to get some bass out of it and thats clipping the amp. Or the subs are going beyond there mechanical limilt and the voice coils are arcing, over heating the amp. Or you really got the load wrong. You know a 4 ohm speaker is not going to read a straight 4 ohm..... right.
Your doing more harm then good man. Your just going to damage you speakers. Don't get me wrong. A well designed free air can sound good. But you have to have the right equipment and the right install.
Old May 23, 2007 | 04:19 PM
eskimo10's Avatar
well actually no I didn't know most of that, and I still don't. What I did figure out is the wiring for them, but I'm definetly interested in learning more about what you posted in there. I wouldn't mind learning a bit from you if you don't mind teaching me lol
Old May 23, 2007 | 05:24 PM
jz98ctr's Avatar
Default Re: (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">
Your doing more harm then good man. Your just going to damage you speakers. Don't get me wrong. A well designed free air can sound good. But you have to have the right equipment and the right install. </TD></TR></TABLE>
X2
ya beat me to it
Old May 23, 2007 | 06:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eskimo10 &raquo;</TD></TR><TR><TD CLASS="quote">well actually no I didn't know most of that, and I still don't. What I did figure out is the wiring for them, but I'm definitely interested in learning more about what you posted in there. I wouldn't mind learning a bit from you if you don't mind teaching me lol</TD></TR></TABLE>
I don't mind teaching you as long as you just not going to make me type for my health. And not put it to use like a lot of noobs around here. They ask for advice then do 100% of the opposite. I not really good at typing anyways. If your local I can give you hands on instructions. If not the net will do well. Are you trying to work with the gear you have or are you trying to go free air?
Old May 23, 2007 | 06:19 PM
eskimo10's Avatar
well actually I'm kind of hoping to do both. I purchased a box for the two audiobahns I have now. so they're no longer working with free air, what are good free air subs? how are infinity?
Old May 23, 2007 | 06:20 PM
eskimo10's Avatar
oh and don't worry I'm not gonna make you type for your health and not put it to use, you deifnetly know what you're talkign about and I'll put to use what you suggest haha
Fat Cash Stack
Audio / Security / Video
22
Apr 8, 2012 09:35 PM
8YourV8
13
Dec 11, 2010 09:50 AM
thatasiankidtony
10
Sep 12, 2007 03:07 PM
eskimo10
May 20, 2007 09:43 AM
SIC_jdm_da9
Apr 23, 2007 10:33 AM
