OEM stereo amp hookup
I am hooking up a sub and amp to my oem stereo in my 94 ls. The major problem is that I have no idea where to wire the remote power wire from the amp to the head unit. Where is the best location to splice that wire so that the amp turns on when I turn my key forward. I am still searching, but what are the wires for the two rear speakers that I need to wire the line out rca converter into? Thanks for everyone who helps me out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alien6067 »</TD></TR><TR><TD CLASS="quote">I am hooking up a sub and amp to my oem stereo in my 94 ls. The major problem is that I have no idea where to wire the remote power wire from the amp to the head unit. Where is the best location to splice that wire so that the amp turns on when I turn my key forward. I am still searching, but what are the wires for the two rear speakers that I need to wire the line out rca converter into? Thanks for everyone who helps me out.</TD></TR></TABLE> You can use the power antenna trigger output or you can use the acc. freepin on the fusebox
94
94
If i read the last part of your question right you were looking for the back wirers too slice in the rca's. If you want to splice them from the radio just look at the color and stripes of the wirers leading the the speaker in the trunk and locate them behind the radio, or the eazy way just take them right from the speaker connections from the back. All in all id probably just buy a new head unit, it would save you alot of trouble, but if this is how you would like too go then good luck. Let us know how it goes.
These are the wires from the OEM harness
Blu/yellow - Lt rear spkr +
red/yellow- Rt rear spkr +
gry/wht - lt rear spkr -
brwn/wht - rt rear spkr -
Yellow/Green - remote wire
