OEM Antenna
Old Aug 27, 2005 | 08:47 PM
ImXposed's Avatar
Needs $$ for a Hooker
Default OEM Antenna
Hey... I would like info on removing the electric antenna from my LS. I can get to it, but I'm kinda feelin shady about disconnecting the hose thing. I need to take it out so I can install my new antenna. pix would be sweet. Id post some of where I got to, cept I dont have a digital camera. thanks.
Old Aug 28, 2005 | 08:29 AM
fcm's Avatar
fcm
Old Fart
Default Re: OEM Antenna (ImXposed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImXposed &raquo;</TD></TR><TR><TD CLASS="quote">Hey... I would like info on removing the electric antenna from my LS. I can get to it, but I'm kinda feelin shady about disconnecting the hose thing. I need to take it out so I can install my new antenna. pix would be sweet. Id post some of where I got to, cept I dont have a digital camera. thanks. </TD></TR></TABLE>What is wrong with the old one?
Go ahead and unplug the "hose thing" it's just a drain hose, as for the rest of it, there should be one 8mm or 10mm nut, around the motor, it holds the bottom of the ant. in place, then there is the "shaft nut" at the base of the mast, [on the outside of the cars body] it is what holds the top of the ant., remove both, unplug the power and ant. lead, done deal. 94
Old Aug 28, 2005 | 09:31 AM
ImXposed's Avatar
awesome, thanks. long as the drain hose won't mess anything else up.
floatfisher
May 11, 2007 06:21 PM
DelSolMarine
Jul 23, 2006 12:52 AM
sgergg454
Jun 5, 2005 05:27 PM
oMek
Nov 10, 2003 09:07 AM
typer.org
Sep 15, 2003 11:06 PM
