new ignition
Thus far I haven't found anything on eBay or AsianWolf. It would be nice though, to have it connected to the starter wires at the driver kick panel ignition harness. They'll be sitting there guessing at the code for hours, never even think to reconnect any wires!!
Good job on the steering wheel removal, this inconveniences the thief by requiring them to bring two vice grips with them, or an expensive aftermarket wheel, which will save your car!! (Car thieves are poor and can not afford vice grips, what dummies.)
Also it'll be pretty cool once installed, because you'll have to take out the steering wheel lock in order to get rid of the key cylinder, so you can turn your wheels even with the car off! This makes it safer, just in case the lock malfunctions and sends you into a wall during a race. Plus you don't have to worry about thieves breaking the lock to steer the car away and causing costly cosmetic damage, it's already gone!
Good luck bro!
vvvvvvv Sup Mesquite buddy? Wonder if I've ever seen your car around.
Good luck bro!
there are some nice kits out their. My point was most (Rookie) installers run to the ignition switch to wire things in. Thus pointing out the wires to use to hot wire the car.
I would leave the key cylinder in just as a added layer. You wouldn't be able to start the car. Giving you more time to respond.
