Neg ground output
Old Jan 5, 2003 | 09:41 PM
B18EG6's Avatar
Default Neg ground output
Negitive ground output...
what does that mean? It is on my warning gauge...does that mean that I should ground my warning light to this "neg ground output" to get the light to illuminate during warn mode?
tia
Sebastian
Old Jan 6, 2003 | 06:10 AM
RaceTilIDie's Avatar
Default Re: Neg ground output (B18EG6)
tia
Sebastian
What kind of gauge is it? Sounds like that is what it's for. However in some cases this wire can't be used as the ground, but are used to trigger a relay which is grounded. It depends on the amp rating on hte wire.
Old Jan 6, 2003 | 05:35 PM
B18EG6's Avatar
Default Re: Neg ground output (EVIL Teken)
its a greddy fuel pressure warning gauge. On their website, its phrased like that.
So if this "neg ground output" is the same as plungers on alarms...then when the gauge activates this output, the current will change from negative to positive?
If I were to hook up an LED or lamp of some sort...should I use the neg ground output for the cathode, or the anode on the LED?
lsvtechatchy
Jul 23, 2010 07:45 AM
bopbop93030
Audio / Security / Video
May 13, 2009 07:35 AM
kroze
20
Oct 29, 2006 02:25 AM
thejacka
Jul 10, 2006 11:03 PM
Civic96LX
Nov 10, 2003 04:11 AM
