need killswitches
Old Oct 11, 2006 | 09:33 PM
hatch96y7's Avatar
Default need killswitches
i need to install some kilswitches but i dont really have time to look threw the searches to many
and the stick doesnt make sense
some one help me out
Old Oct 12, 2006 | 12:53 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: need killswitches (hatch96y7)
no one is going to help you out if you say you are lazy. Are you comfortable working on your car and do you know 12 volts
Old Oct 12, 2006 | 04:10 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i need to install some kilswitches but i dont really have time to look threw the searches to many
That's definitely not how it works around here, guy... And it's "through"... And use some punctuation and better sentence structure and we'll be more apt to help you.
Old Oct 12, 2006 | 02:45 PM
hatch96y7's Avatar
Default Re: (B18C_EJ8)
so because i cant spell on a computer right................ and i dont want to search threw each and everyone of these dead end threads that have old pics i cant see anymore....................... ur gonna let me possibly get jacked ....................thats cold i thought this was ht guess not no more
Old Oct 12, 2006 | 02:46 PM
hatch96y7's Avatar
Default Re: (hatch96y7)
but hanks anyways i guess ill just search
Old Oct 12, 2006 | 04:28 PM
fcm's Avatar
fcm
Old Fart
LOL, I think they are both having a bad day.
What is it you want to do?
A simple 1A SPST, [on/off] toggle switch installed, [hidden] on the coil ground for injector power relay in the "PGM-FI Main Relay", [also called main relay or fuel pump relay] will shut down the injectors and the fuel pump. 94
Old Oct 12, 2006 | 04:33 PM
hatch96y7's Avatar
Default Re: (fcm)
thanks very much i am going to day to pick up a switch from radio shack and a relay then i have the wire and wire stripper.
where is the coil that i wire it to do i just tap int the wire or connect the wire from the sitch into the wires in the coil
thanks
Old Oct 12, 2006 | 04:34 PM
hatch96y7's Avatar
oh i mainly just want a kill switch for the fuel and the ignition
and maybe for two other things so i can have switches everywhere maybe for the lights so if they steal it during the night the have a good chance of getting caught
Old Oct 12, 2006 | 05:55 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and i dont want to search threw each and everyone of these dead end threads that have old pics i cant see anymore....................... ur gonna let me possibly get jacked ....................thats cold i thought this was ht guess not no more
Oh boo hoo... It's just so terribly hard to scroll through the pages of the DIY thread... If you had looked at page 3, there are pretty pictures that show you exactly what you need to do. You don't even need to read those pesky words in the first two pages...
Old Oct 12, 2006 | 08:32 PM
I will help anyone thats willing to help his or her self Sorry If i seemed to come off rude but look at your post. Make sure the install is clean and you can't tell that it was there. I just fixed 3 members cars to day that kill switchs were garbage. I wish I could of posted pictures. But If you can not do the job right do not do it at all. It will be a waste of time and your car will probably end up being stolen anyways. Kill switches teamed up with a alarm is the way to go. You need attention brought to the car. The kill swithes will not do that. It will just slow them down. You are local, If you want. You buy the material. You work on your own car. I'll show you how to do it right. I will be doing one sunday so you can take notes.
Old Oct 12, 2006 | 10:59 PM
hatch96y7's Avatar
Default Re: (wrx-killer-Sti eater)
alrite coo where u doing it at bought a switch today just to test it out but plan on putting in like four switches 2 to the ignition in diffrent spots then 1 to the fuel and then 1 to the lights
Old Oct 13, 2006 | 09:36 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 &raquo;</TD></TR><TR><TD CLASS="quote">thanks very much i am going to day to pick up a switch from radio shack and a relay then i have the wire and wire stripper.
thanks</TD></TR></TABLE> Not the coil, the ground for the coil, the ground for the injector coil is low current, [relay not needed] you only need a 1A switch, the ground lead is on the PGM-FI Main Relay plug/harness, normally found up under dash drivers side.
You will use a SPST, [on/off] switch, ground lead is cut and the two cut ends are connected to the two terminals of the switch.
What is the mm&y of car?94
Old Oct 13, 2006 | 10:27 PM
hatch96y7's Avatar
Default Re: (fcm)
i bought a switch today its an spst switch i think its illuminated and has three prongs in the back my car is a 96 civc dx hatchback
Old Oct 13, 2006 | 10:33 PM
hatch96y7's Avatar
thanks for all ur help ill be doing this tommorow since u said i dont need a relay .......................so lets sree if i got this ..................i look for thr relay under my dash that leads to the fuel injection then i take the ground wire from there and i connect them too the two outer prongs of the connection then im done
thanks for all ur help its very much appreciated
Old Oct 14, 2006 | 10:09 AM
fcm's Avatar
fcm
Old Fart
Unlike most Honda/Acuras the relay on a 96 Civic is apparently on the right side... http://www.tegger.com/hondafaq/mainrelay.html
The switch you have is much bigger then you need, and it is the wrong switch, you need a small, 1A on/off switch that you can hide, you certainly do not need a light.
Something like this...
http://cgi.ebay.com/ws/eBayISA...58169
There is only one black wire on the PRM-FI Main Relays plug, if you cut that black ground lead, it will "immobilize" the car, install the switch so you can open and close the circuit, [ground]. 94
Old Oct 14, 2006 | 12:06 PM
hatch96y7's Avatar
Default Re: (fcm)
alrite thanks alot ill tell u how it goes
Old Oct 14, 2006 | 12:07 PM
hatch96y7's Avatar
and also if i want to install a kill switch for my headlights ..........can i do that by just hooking up the two grounds to the switch also
Old Oct 14, 2006 | 12:28 PM
hatch96y7's Avatar
and will the switch that i have still work the same
Old Oct 14, 2006 | 12:39 PM
fcm's Avatar
fcm
Old Fart
The head lights are a 30A circuit, so you would need a 30A switch, or just use a relay on the white 12V+ input to the "Combination Light Switch", from fuse 48 -30A, [hot at all times] in under hood fuse box, the white lead runs from under hood fuse box to the under dash fuse box and then to the "CLS", you could even use the same toggle installed on the injector relays coil ground to control the head light relay. 94
Old Oct 14, 2006 | 11:13 PM
hatch96y7's Avatar
Default Re: (fcm)
the switch that i bought is a 30 a i will use that one first.
Old Oct 14, 2006 | 11:14 PM
hatch96y7's Avatar
or should i use that for the fuel pump or ignition
Old Oct 15, 2006 | 07:44 AM
fcm's Avatar
fcm
Old Fart
As I said, you only need a 1A switch for the injector relays coil ground, so use the switch for the head lights. 94
Old Oct 15, 2006 | 09:35 AM
hatch96y7's Avatar
Default Re: (fcm)
okay thanks gonna try it today
Old Oct 15, 2006 | 03:06 PM
hatch96y7's Avatar
wait i got a rocker 10a at 125vac
or 6a at 250 vac
what can i use this for
Old Oct 15, 2006 | 04:31 PM
fcm's Avatar
fcm
Old Fart
Again it's bigger then you need, and it makes hiding them harder, you can use the switch to control any circuit that is 10A or less. 94
