Need input on new system setup
Old Mar 17, 2005 | 10:25 AM
Wo-Nelly's Avatar
Default Need input on new system setup
I'm planning on getting 2 10's, http://www.infinitysystems.com/carau...er=KPE&Cat=SUB But I'm wondering which amp I should get. I'm looking at either the Phoenix Gold Xenon 600.1 or the Octane-R 8.0:1 Which one should I go for? Also how would I wire them up? I found some diagrams HERE to follow but a little unsure which one to use.
Old Mar 17, 2005 | 06:03 PM
fcm's Avatar
fcm
Old Fart
Default Re: Need input on new system setup (Wo-Nelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wo-Nelly &raquo;</TD></TR><TR><TD CLASS="quote">I'm planning on getting 2 10's, http://www.infinitysystems.com/carau...er=KPE&Cat=SUB But I'm wondering which amp I should get. I'm looking at either the Phoenix Gold Xenon 600.1 or the Octane-R 8.0:1 Which one should I go for? Also how would I wire them up? I found some diagrams HERE to follow but a little unsure which one to use.</TD></TR></TABLE> Looking at the specs, the Xenon 600.1 looks like the better amp for what you want to do, also I would not use wiring option # 1 or 2, and am suprised they do no show option #3 wire the VCs in parallel, [4ohm and 4ohm paralled is 2ohms then wire the speakers in series, 2ohm and 2ohm in series is 4ohms, best way to wire them, go to http://www.the12volt.com clik on parallel series under car audio. 94
Old Mar 18, 2005 | 07:32 PM
ANDREW D's Avatar
Default Re: Need input on new system setup (fcm)
I suggest NOT to go with the Octane series. Personally, I think that line sucks. They're like a friggin tonka toy. Xenon amps are not bad. Try and track down a Tantrum series amp. It's good ****, unfortunally, its discontinued.
ShadowTeg
Audio / Security / Video
Mar 3, 2009 08:54 AM
Fo-Do Fanatic
Oct 9, 2007 04:09 PM
TedR719
Mar 11, 2007 12:47 PM
AiL45
32
Aug 29, 2006 08:32 AM
pezzy
Sep 5, 2004 12:06 PM
