Need help with wiring for integra
Old Nov 15, 2007 | 07:33 PM
fastcrvi's Avatar
Default Need help with wiring for integra
need to find the following, for the ones like ebrake or trunk, i need other locations other than ebrake or trunk itself, like further out and color of the wire
negative (-) wire for parking lights or hazard switch 97 integra 2 door ls 5 speed.
ebrake wire (-) negative
dome light (-) negative
trunk open signal (-) negative
any help appreciated. already know obious locations except for parking lights
thanks
Modified by fastcrvi at 9:07 PM 11/15/2007
Old Nov 15, 2007 | 07:48 PM
8520's Avatar
Default Re: Need help with wiring for integra (fastcrvi)
http://causeforalarm.thecarthi....html
Old Nov 15, 2007 | 08:10 PM
fastcrvi's Avatar
Default Re: Need help with wiring for integra (8520)
https://honda-tech.com/zerothread?id=718593 - this one is by far better.. but still doesn't answer my questions
Old Nov 15, 2007 | 08:28 PM
8520's Avatar
Why are you looking for a negative parking light wire?
The ebrake wire you could grab behind the cluster I'm sure, the dome light at the actual dome light, and you shouldn't have a "trunk open signal", unless you're referring to a trunk pin.
Ya know you could always try tracing things or probing them with a multimeter.
Old Nov 15, 2007 | 10:17 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcrvi &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=718593 - this one is by far better.. but still doesn't answer my questions</TD></TR></TABLE>
Yes, it really does. It has the location of everywire that you asked about. What seems to be the problem?
Old Nov 17, 2007 | 10:55 AM
eecyclone's Avatar
Check this page out. Should help quite a bit.
http://www.team-integra.net/se...D=217
Old Nov 17, 2007 | 02:29 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcrvi &raquo;</TD></TR><TR><TD CLASS="quote">negative (-) wire for parking lights or hazard switch 97 integra 2 door ls 5 speed.
trunk open signal (-) negative</TD></TR></TABLE>
There is no neg.(-) parking light wire.
"E" brake lead can be found in cluster plug.
Dome light neg.(-) is the same as door trigger.
Trunk/hatch is a green lead in blue plug above fuse box. 94
Old Nov 17, 2007 | 10:22 PM
twogengsr's Avatar
Default Re: Need help with wiring for integra (fcm)
neg parking light wire is blue with red tracer @ factory alarm plug can also catch it VERY high in driver kick panel
Old Nov 18, 2007 | 07:54 AM
fcm's Avatar
fcm
Old Fart
Default Re: Need help with wiring for integra (twogengsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twogengsr &raquo;</TD></TR><TR><TD CLASS="quote">neg parking light wire is blue with red tracer @ factory alarm plug can also catch it VERY high in driver kick panel</TD></TR></TABLE> Your sure about that, my wiring schematics for a 97 teg does not indicate any neg.(-) park light lead and other then the front side markers there is no relay in the park light circuit. 94
Old Nov 21, 2007 | 11:57 AM
twogengsr's Avatar
positive
Old Nov 22, 2007 | 05:40 AM
fcm's Avatar
fcm
Old Fart
Took three 97 Tegs to find it, neg.(-) park light is only available if car equipped with OEM alarm, it drives the alarms light flash relay, also only there if OEM alarm is. You learn something new every day. 94
Old Nov 22, 2007 | 09:22 AM
twogengsr's Avatar
im old
Old Nov 22, 2007 | 04:09 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twogengsr &raquo;</TD></TR><TR><TD CLASS="quote">im old </TD></TR></TABLE> LOL, no I'm old 94
Old Nov 22, 2007 | 07:58 PM
fastcrvi's Avatar
isn't there a harness plug for oem alarm? above where cruise control would go?
attached via clear plastic tape.
have another question.. if parking light wires are red/black.. does that mean no other wire will be same color/pattern? when looking at harness, i see brake wire all over the place in different harnesses..
i looked over all wiring and seems like only ignition related wires will be black/yellow.. so does same goes for the rest.. say all tach wires will be blue or if color changes its still not matched by any other type of wire..
Old Nov 22, 2007 | 08:07 PM
8520's Avatar
No. Many cars you will find multiples of the same color doing different things.
Old Nov 23, 2007 | 04:29 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^^
That is why it is important to to meter the wire to confirm it is the correct lead you need. 94
Old Nov 23, 2007 | 05:09 AM
fastcrvi's Avatar
with that in mind... isn't there some type of manual that identifies every connector/wire?
Old Nov 23, 2007 | 11:15 AM
twogengsr's Avatar
there is an alarm plug its taped up there in the driver......... very high VERY high also it very easy to catch parking brake wire at lever in center console you will see the parking brake wire i think is green with a red tracer its a single wire one you see it youlll know what im talking about
Old Nov 23, 2007 | 01:17 PM
fastcrvi's Avatar
thanks!
any other locations for IGN2 except for yellow wire of ignition harness or dashboard harness that plugs into underdash fusebox??
Old Nov 24, 2007 | 06:17 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcrvi &raquo;</TD></TR><TR><TD CLASS="quote">with that in mind... isn't there some type of manual that identifies every connector/wire?</TD></TR></TABLE> Yes, a shop manual, but for alarm/remote starts a tag in sheet is all you should need... http://64.85.6.121/diagrams/pr...eID=6 94
Old Nov 24, 2007 | 09:21 PM
fastcrvi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Yes, a shop manual, but for alarm/remote starts a tag in sheet is all you should need... http://64.85.6.121/diagrams/pr...eID=6 94</TD></TR></TABLE>
yeah, i got both helms service and haynes.. they just dont go into details about every connector, helms identifies all of them but would be nice if they identify every wire as well..
btw, any other locations for IGN2 except for yellow wire of ignition harness or dashboard harness that plugs into underdash fusebox??
Old Nov 24, 2007 | 09:57 PM
8520's Avatar
btw, any other locations for IGN2 except for yellow wire of ignition harness or dashboard harness that plugs into underdash fusebox??</TD></TR></TABLE>
If you want to know every plug and connector look at a factory service honda manual.
Go to http://www.hondahookup.com/manuals/ and register.
Old Nov 25, 2007 | 06:48 AM
fastcrvi's Avatar
i have factory service manual from helms and haynes.. it doesn't describe every wire on every connector..
the only other thing i need at this point is other locations for IGN2 except for yellow wire of ignition harness or dashboard harness that plugs into underdash fusebox
Old Nov 25, 2007 | 06:58 AM
fcm's Avatar
fcm
Old Fart
Yellow is ACC. not ign. 2 your car does not have an ign. 2, it has a 2nd ign., [hot in run but not in start].
The yellow is hot in acc. and run but not start. 95
BTW, what are you installing???
Old Nov 25, 2007 | 07:35 PM
fastcrvi's Avatar
yep, you are right, i wasn't looking at diagram at the time writing this.. so where else can i find 2nd ignition except for ignition harness or dashboard harness??
