Need help Viper 500HF
Old Aug 20, 2007 | 12:03 PM
MonkeyPuzzle's Avatar
Default Need help Viper 500HF
So I bought a used car which already has a Viper 500HF alarm installed.
As is typical its a terrible job!
So the previous owner told me he got sick of the alarm so he removed one of the fuses.
Now I would like to sell the car and the alarm is at least a small selling point.
So my problem is when I put the fuse back in the alarm goes off. I then try to disarm it using the key and the valet switch and the remote, but no joy.
Anyone have any ideas? Anyone installed one of these and have the install manual, all I have is the owners manual which is basically just advertising.
Old Aug 20, 2007 | 04:00 PM
suspendedHatch's Avatar
Default Re: Need help Viper 500HF (MonkeyPuzzle)
You might be able to find the manual in the "alarm manual" section linked in the security thread in the FAQ sticky at the top of the forum.
You probably need to reprogram the remote to the alarm since it's been uplugged for so long. Because of the code hopping, it will be out of sync.
Old Aug 20, 2007 | 04:09 PM
8520's Avatar
Default Re: Need help Viper 500HF (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">
You probably need to reprogram the remote to the alarm since it's been uplugged for so long. Because of the code hopping, it will be out of sync.</TD></TR></TABLE>
+1 on that, but if it's not disarming with the valet switch and key, then either the code was changed, the op isn't doing it right, or something's fubar
Old Aug 21, 2007 | 06:41 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misanthropist &raquo;</TD></TR><TR><TD CLASS="quote">+1 on that, but if it's not disarming with the valet switch and key, then either the code was changed, </TD></TR></TABLE> Valet/override is not coded on a 500HF.
MonkeyPuzzle make sure you are pressing the valet button and not the VRS button...
http://www.directeddealers.com...V.pdf 94
Old Aug 21, 2007 | 08:14 AM
8520's Avatar
Default Re: Need help Viper 500HF (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Valet/override is not coded on a 500HF.
Whoops, I thought all dei alarms valet switches could be coded :S
dFreezy
Audio / Security / Video
Aug 9, 2010 01:34 PM
honda305
Apr 24, 2007 07:20 PM
253teg
Jun 29, 2006 09:12 PM
MooreBoost
Mar 22, 2004 05:39 AM
9five1five
Oct 23, 2001 04:28 PM
