need help with removal...
Old Feb 27, 2006 | 06:25 PM
stevelive3's Avatar
Default need help with removal...
my friends has a 99 civic lx, she asked me to put a cd player in it, i cant figure out how to get the plastic piece off that goes around it, im talking the big piece that holds the climate controls and hazard button... any help/tips would be awsome. thanks
Old Feb 28, 2006 | 07:43 AM
B18C_EJ8's Avatar
http://www.installdr.com
Old Feb 28, 2006 | 09:59 AM
White95SiHB's Avatar
Default Re: need help with removal... (stevelive3)
http://www.installdr.com/Insta...5.pdf
Go to page 5 of the .pdf file.
Old Feb 28, 2006 | 11:35 AM
fcm's Avatar
fcm
Old Fart
Ditto both the above, but the instructions, [step 12] are a little misleading, 2nd sentence, "But, the wiring attached to the rear of the radio is secured with clips to the frame of the dash" It is the radio/climate control housing that is clipped to the dash, and although unplugging the brown an blue plug may help, [they will have to be unplugged anyway] it will not make it any easier to "unclip" the housing, best way is to press, [from behind] on the housings mounting bracket, the one that the 2 rear 8mm machine screws go into, it will "pop" out the bottom of housing enough for you to get your fingers in behind the housing edge, without pulling the bottom of housing out too much, [rest of clips will only bind] grab hold of housing firmly with both hands and with a quick short jerk straight out, "pop' the rest of the clips free, some of the clips may come off the housings "clip posts" find them and reinstall them on the "posts. Do NOT use any kind of pry tool between the housing and dash, you WILL damage the dash. 94
mrmckie
Sep 21, 2006 01:44 PM
davidnguyen
Audio / Security / Video
Apr 26, 2005 09:05 AM
Deerslayer
Sep 15, 2004 06:50 PM
99fbpem1
May 18, 2004 06:17 PM
awalk2005
Jul 15, 2003 08:22 PM
