Need help with Panel Removal!!! Windo Crank
Old Nov 2, 2003 | 08:39 AM
StreetGT's Avatar
Default Need help with Panel Removal!!! Windo Crank
Well i just got some 6 1/2" Type S for upfront and im having a hard time getting it to lineup to screw it down. Well i want to get the damn door panel off for a lil more room but i cant get the damn window crank off? So how can i get that thing off?
Old Nov 2, 2003 | 10:53 AM
FatJoe's Avatar
Default Re: Need help with Panel Removal!!! Windo Crank (StreetGT)
theres a pin inside there that is shaped like a horseshoe... you have to bend back the plastic circle piece that is seperate from the crank and look in there. it will be flush with the crank itself. get some pliars or something skinny enough to fit in there and pluck it out. then it jus comes right off.
Old Nov 2, 2003 | 01:54 PM
StreetGT's Avatar
Ok i think i know what your talking about iw ill try that
Thanks
Old Nov 5, 2003 | 08:49 PM
94EG6HB's Avatar
Default Re: (StreetGT)
Use a towel.
put bettwen the door panel and crack.
pull side to side gently.
dopamean
Nov 19, 2008 08:22 PM
cashkeith
May 29, 2008 06:55 AM
94EeGe
Jul 12, 2004 11:20 AM
okman16
26
Nov 9, 2003 12:48 PM
Mentat Ghola
Jan 11, 2003 04:47 PM
