Need help with alarm install
Old Nov 25, 2005 | 04:59 PM
tthomass's Avatar
Default Need help with alarm install
I just finished, or so I thought, an install on a 2002 Chevrolet Silverado 2500HD. I put a Viper 791XV on it. I hooked every wire up to what my wiring schematic said. Here's the wiring schematic: http://www.the12volt.com/insta...&PN=4
After hooking everything up, I'm trying to program it. I'm going by the instructions in the book and it doesn't do anything. No siren chirp, no LED flashing. When I push the button for the remote like I'm programming it to a channel, the remote beeps at me saying it can't send a signal like it's out of reach. I checked my door trigger connection and my pink wire (can't remember what it goes to) as these are the only two required to program it. The valet button is plugged in as is the antenna. The alarm is getting power because I can pluck the shock sensor and its LED will light up. What could it be?
Old Nov 26, 2005 | 08:35 AM
fcm's Avatar
fcm
Old Fart
Default Re: Need help with alarm install (tthomass)
The door trigger, [green (-) in your case] and the ign., [pink] are not the ONLY ones needed, they are the ones you have to have.
To program the remote, are you opening the door and leaving it open, turning on the ign. and leaving it on, then pushing valet button one time releasing and then pushing and holding it, at this point the siren should chirp one time and the LED should blink one time, then press and release the arm/lock button on remote.
If you are not getting the chirp and KED flash once you press and hold the valet button you are not getting into the "transmitter/receiver learn routine".
Take my be for a number of reasons, improper power or ground for unit, or the pink is not connected properly, [to ign. 1] or the door trigger, [green] is not connected properly, [to the tan and orange wires at the BCM] or the diodes are backwards. http://www.directwholesale.net...LLDOG this may help. 94
Old Nov 26, 2005 | 09:15 AM
eastsidekustomz's Avatar
Default Re: Need help with alarm install (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> once u get that then hit the LOCk button on the alarm key fob. it should be at factory default
Old Nov 26, 2005 | 10:48 AM
tthomass's Avatar
I checked the door triggers and even undid them and just hooked straight into the driver's door only trigger without a diode. The pink wire is on the 1st ignition and I double checked it. For power, I ran a power wire straight from the battery through the firewall to the brain. The ground is on a bolt that is on the door frame, so that should be good. It never chirps or blinks and doesn't enter the learn routine. I am following the instructions which are the same as you state, but nothing happens. I'm lost.
Old Nov 26, 2005 | 04:44 PM
suspendedHatch's Avatar
Plug the antenna into the brain and not the remote start satellite.
Old Nov 26, 2005 | 09:00 PM
tthomass's Avatar
Default Re: Need help with alarm install (suspendedHatch)
the antenna is plugged into the brain. Would not having the remote start satelite hooked into the brain be the problem as now that I'm thinking of it it probably is. DAMNIT. MUST TRY THAT.
Old Nov 27, 2005 | 06:14 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthomass &raquo;</TD></TR><TR><TD CLASS="quote">the antenna is plugged into the brain. Would not having the remote start satelite hooked into the brain be the problem as now that I'm thinking of it it probably is. DAMNIT. MUST TRY THAT.</TD></TR></TABLE>Yes that will be the problem. 94
Old Nov 27, 2005 | 04:26 PM
tthomass's Avatar
How do you add a remote to the system? The remote that came with it is not being used, it's a replacement remote that is.
Old Nov 28, 2005 | 10:28 AM
fcm's Avatar
fcm
Old Fart
Open door, [door trigger must be hooked up]
Turn on ign., [the pink wire must be hooked up]
Press and release valet button one time.
Press and hold valet button, siren will chirp and LED will flash one time.
Within 15 sec. press and release lock/arm button on remote, the siren will chirp, you can now release valet button, remote is programmed to default. 94
Old Nov 28, 2005 | 04:50 PM
tthomass's Avatar
work'n..........woo hoo, thanks for the help, time for clean up and tucking away
byronl
Audio / Security / Video
12
Mar 27, 2008 01:51 PM
PINKS
27
Mar 23, 2006 02:06 PM
PINKS
Mar 12, 2006 11:29 PM
ivanson
Feb 26, 2006 07:32 PM
Average DA9
Aug 17, 2004 07:27 PM
