need help with alarm
Old Nov 28, 2004 | 05:21 PM
kac3r's Avatar
Default need help with alarm
just bought a scytek 5000rs 2w-1 2 way alarm system with remote start . friend bought the exact same 1 and i installed it into his car 92 hatch cx everything works. but when i mocked it up on my car it worked but after i took it out and lengthened the wires because you know how shops just install it quick and leave the main box under your dash. anyways did the wires and reinstalled the whole system and now it doesnt work all wires were checked alot of times and the connections are secure. when i try to arm the dam thing it just blinks this hand and thats all
Old Nov 28, 2004 | 06:46 PM
fcm's Avatar
fcm
Old Fart
Default Re: need help with alarm (kac3r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kac3r &raquo;</TD></TR><TR><TD CLASS="quote">just bought a scytek 5000rs 2w-1 2 way alarm system with remote start . friend bought the exact same 1 and i installed it into his car 92 hatch cx everything works. but when i mocked it up on my car it worked but after i took it out and lengthened the wires because you know how shops just install it quick and leave the main box under your dash. anyways did the wires and reinstalled the whole system and now it doesnt work all wires were checked alot of times and the connections are secure. when i try to arm the dam thing it just blinks this hand and thats all</TD></TR></TABLE>Is it in valet mode 94
Old Nov 28, 2004 | 07:18 PM
kac3r's Avatar
im pretty sure its not in valet mode. id turn my ignition on and press the override button but no luck...
Old Nov 29, 2004 | 07:52 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kac3r &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure its not in valet mode. id turn my ignition on and press the override button but no luck...</TD></TR></TABLE> If doing that, does not switch it in and out of valet, the alarm may be latched up, try unplugging the main alarm plug, [the one with the power wire in it ] wait a few sec. and plug it back in again, if its latched up that should reboot it. 94
Episode
Audio / Security / Video
Oct 12, 2010 02:28 PM
dragonfly2k3
Dec 20, 2007 05:34 PM
The Alchemist...
Apr 22, 2005 07:54 PM
erikiksaz1
Mar 16, 2004 04:08 PM
