need help
Old Nov 14, 2005 | 11:09 AM
PreludeSi94's Avatar
Default need help
i got a multimeter, which setting would i put it on to test wires and find a short?and what range would it jump to?
Old Nov 14, 2005 | 01:08 PM
fcm's Avatar
fcm
Old Fart
Default Re: need help (PreludeSi94)
If you are looking for, say a wire shorted to ground, set it to "continuity" that's the one that when you touch the probes together the meter will beep a steady tone as long as they are touching, ground one probe to the cars chassis, and test the wires, when you hear the beep you have found the short, the meter will also read 000 for a dead short, but it can also beep, [and "show" a short] under other circumstances, EG: if the fuse for the dome light was blown and you probe the pos. (+) lead running to the light, and a door is open, [dome light has a ground] the meter would see that as a short and would beep.
This should help http://www.acmehowto.com/howto...e.php
Hope this helps, feel free to IM me if you need more help. 94
JasinC19
Jun 7, 2013 11:16 AM
gfunkmos37
Jan 21, 2005 08:24 PM
rocco
Jun 20, 2004 11:59 AM
