My Sensor???????
Old Jun 2, 2005 | 07:55 PM
ExclusiveCRX's Avatar
Default My Sensor???????
It has been 1 week since i took out the stock seat belts and put in my 4 point harnesses on my crx. i tried snipping the wires within the doors but the damn thing wont stop beeping i was told that it was my sensor that had to be taken out but i have no idea where it is and the beeping noise and flashing lights are driving me up a wall! I have a 91 crx dx! Someone please help me locate it!
Old Jun 3, 2005 | 08:53 AM
fcm's Avatar
fcm
Old Fart
Default Re: My Sensor??????? (ExclusiveCRX)
What wires did you "snip" in the doors
Did your CRX not have a small 2 pin plug on the on the inside seat belts? You should be able to just cut the plug, [on the seat belt] off, connect the 2 wires together and plug it into, [close the loop] the plug that comes out from under the carpet where the seat belt was mounted.
On the newer Honda/Acuras. [ newer then 91 and up to at least 94 my teg is a 94] that have the inside part of the seat belt mounted to the seat itself, the plug is under the seat, [clipped to the underside of the seat, I think the same thing applies though. 94
Modified by fcm at 8:54 AM 6/10/2005
Old Jun 7, 2005 | 04:12 PM
i snipped the wires that split to make the 2 connectors inside the seats, and i dont get what you mean by connecting the one on the floor with the one on the door
its impossible because then i couldnt open the door!
Old Jun 8, 2005 | 08:37 AM
fcm's Avatar
fcm
Old Fart
Default Re: (ExclusiveCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExclusiveCRX &raquo;</TD></TR><TR><TD CLASS="quote">i snipped the wires that split to make the 2 connectors inside the seats, and i dont get what you mean by connecting the one on the floor with the one on the door
its impossible because then i couldnt open the door!</TD></TR></TABLE>You misunderstand..I said nothing about connecting any wire from under the seat to to a wire in the door.
You said......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExclusiveCRX &raquo;</TD></TR><TR><TD CLASS="quote">i tried snipping the wires within the doors</TD></TR></TABLE>
I asked.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">What wires did you "snip" in the doors</TD></TR></TABLE>
Pleas read my post again 94
Old Jun 9, 2005 | 04:10 PM
i snipped all of the wires in the door panel
Old Jun 10, 2005 | 08:02 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExclusiveCRX &raquo;</TD></TR><TR><TD CLASS="quote">i snipped all of the wires in the door panel
</TD></TR></TABLE> The wires in the doors will have nothing to do with the seat belt chimes, I checked on my 94 teg and my sisters 92 civic and on both the chime stops working, the 2 pin plug is on the bottom of the seat on both cars. Was the 2 pin plug on your crx on the bottom of the seat, or was it plugged into the inside part of the seat belt, [the drivers right hand part]? 94
EGed up from the seat up
Feb 4, 2010 10:06 AM
CRXguy_88
Jan 14, 2010 09:43 PM
mxteam
Aug 1, 2007 01:35 PM
HondaPH22
Honda S2000
Dec 26, 2006 05:17 PM
