mtx separates speaker wont work
Old Feb 21, 2009 | 09:12 AM
Turbo_Mike's Avatar
Default mtx separates speaker wont work
IN my gmc truck it came with mtx separtes in the front door that are fairly new. they were installed by circuit city. I noticed the other day though that only the tweeters are working, and the speakers are not (On both sides)
I checked out all the wiring and it looks good from what i can tell, secure soddered connections...any ideas.
Thanks for any help please
Old Feb 21, 2009 | 10:30 AM
fcm's Avatar
fcm
Old Fart
Default Re: mtx separates speaker wont work
Blown mids, blown passive x-overs, if there is an amp make sure x-over point is not set to high or if there is a 1x/10x switch, that it set to 10x.94
Old Feb 21, 2009 | 12:05 PM
Turbo_Mike's Avatar
no amp, its run off the stock deck. I did notice a round black thing with a wire coming out of each end of it in teh crossover. One end was connected and the other was not, so i poked it down thru the board again and resoddered it...still no luck.
I'm gonna pull the other door apart and see if the passenger side looks the same. Would that have been repairable or if it had come detached then its done for?
Old Feb 21, 2009 | 01:55 PM
fcm's Avatar
fcm
Old Fart
Try this, remove a speaker and touch the terminals with a batt. [AAA, AA, C, D or 9V will work] pos.(+) terminal of batt. to pos.(+) speaker terminal, neg.(-) terminal of batt. to neg.(-) speaker terminal, you should hear a "pop" and speaker cone should move out, it you reverse the batt. you still get the "pop" but cine moves in, if you hear the "pop" then the no sound problem is not in the speaker.
What is the model number of the speakers? 94
Old Feb 21, 2009 | 03:23 PM
Turbo_Mike's Avatar
sweet, i'll try that tomorrow... i tried to tape the spade connectors of truck harness to the speaker wires and turn the radio on and the speaker didnt work, but it was cold and possible the connections werent good. I find it hard to believe that two fairly new 6" mtx speakers would go bad, but i'll test them tomorrow. thanks
Old Feb 25, 2009 | 07:07 PM
Turbo_Mike's Avatar
Yea speaker doesnt seem to work, i tried it with a few different batteries
And they are the tx6001s
Old Feb 26, 2009 | 06:08 AM
fcm's Avatar
fcm
Old Fart
If you can not get the speaker to "pop" with a batt. the speaker is NG. 94
Old Feb 27, 2009 | 04:06 AM
Turbo_Mike's Avatar
bummer.
thanks for the help 94
brads94accord
Audio / Security / Video
Jan 28, 2021 02:29 PM
oheim
Honda S2000
Dec 10, 2009 05:52 AM
Jose-aka-Pedro
12
Dec 5, 2006 05:40 AM
watacivic
Mar 13, 2004 12:45 PM
