Major Complicated Issue-DEI Python 990
Old Dec 20, 2008 | 12:41 PM
lmike6453's Avatar
Icon6 Major Complicated Issue-DEI Python 990
*Hey, here's the story...
up until yesterday, my car starts very weak, but only by remote starting. I tested voltage and while cranking, the 3 red wires get 11.9v but the purple wire(starter wire) only gets 7.9-8.0v. The car does not start remotely, but perfectly by key.******
The huge issue now...
this morning my car gets no acc power or any power at all. With my battery disconnected and trying to jump from a civic, still now power. The engine bay fuses are fine and the 2 15amp ign/acc fuses in the engine cabin are fine when checked. What else should I check.
PLEASE help!! pretty please LOL
EDIT: PARAGRAPH 2 FIXED
Old Dec 20, 2008 | 01:03 PM
siRone's Avatar
What kind of vehicle?
Old Dec 20, 2008 | 01:07 PM
lmike6453's Avatar
97' Acura Integra RS
Old Dec 20, 2008 | 01:46 PM
siRone's Avatar
Did you check all the fuses? Check yr ground. Make sure you have a good ground. Do a cell test on the battery too. I know you used jumpers but it might b a good idea to just pop yr friends battery in. Make sure yr chasiss ground at the battery is good too.
Also check the big battery fuse under the hood. I think its a 100 or 60 amp.
Old Dec 20, 2008 | 07:32 PM
lmike6453's Avatar
K ty i will have an update on Monday
Old Dec 21, 2008 | 08:48 AM
lmike6453's Avatar
Default Re: Major Complicated Issue-DEI Python 990
Ok, i actually got it to start. The issue was the main fuse. Thanky ou very much.
Now my issue remains to be the 7.9v on the starter wire of remote start. The car does not remote start and pulleys spin slow when trying to crank.
Old Dec 21, 2008 | 11:57 AM
fcm's Avatar
fcm
Old Fart
Make and model of remote start?
It will be a bad starter relay in the remote start.
Depending on make and model of remote start there may be a "5th relay" that can be used for start. 94
Old Dec 21, 2008 | 12:50 PM
lmike6453's Avatar
Python 990(DEI)...please elaborate on this relay. With the knowledge of what to do, I may be able to resolve my issue.
Old Dec 21, 2008 | 04:13 PM
siRone's Avatar
The shitty thing is that dei uses the new style satelite relay pack which seems to be all in one instead of the oldschool sat relay pack where you could just simply unplug a relay and plug another in.
Old Dec 21, 2008 | 04:59 PM
lmike6453's Avatar
Ah I see. So I guess I have to try to replace the brain first? So I don't have to rewire....where I can remove the brain and car still starts?
Old Dec 21, 2008 | 05:07 PM
siRone's Avatar
You mean the sat pack right? I highly doubt the brain is the problem but u never know. DEI is pretty reliable.
Old Dec 21, 2008 | 05:14 PM
fcm's Avatar
fcm
Old Fart
Yep, a problem, your Integra does not need to use the "5th relay", on a DEI remote starts relay satellite there is an extra relay, #7- pink/white (+) output for 2nd ign., it can be programed, [menu #3 remote start options, 3-9] but here's the problem, it can only be programed as 2nd ign. or 2nd acc. not 2nd starter, [like just about every other remote start on the planet].
You have 3 options, "open" the relay satellite, remove the defective start/anti grind/starter cut relay and replace it with the unused 5th relay, will take soldering/de-soldering skills and tools, replace the relay satellite or do some rewiring, install a relay for starter cut, connect the heavy gauge pink/white to the starter wire, [downstream of the starter cut relay.
In the ribbon harness, at a plug, de-pin and switch the pin positions of the pink/white and violet leads, you will not be using heavy gauge purple and green leads that are now connected to the cars starter wire, remove them compleatly.
You are also going to need the H1/12 orange armed output, [from main harness] to control the starter cut relay you install.
Not sure is the orange lead is "energized' when in remote start mode so not sure if you will still have anti grind. 94
Old Dec 22, 2008 | 10:27 PM
lmike6453's Avatar
Wow thanks for the input but that's a lot of work. I am capable of it, however that's going to take a long time to do compared to a relatively "easy" fix.
Old Dec 23, 2008 | 12:16 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
send me the onld one and I'll send you a new relay pack. Hows thats?
Old Jan 2, 2009 | 04:39 PM
lmike6453's Avatar
That sounds great, but what's the damage?
bump2pass
Apr 4, 2016 07:29 AM
petty$rep
Feb 2, 2008 10:25 AM
MI4$DC5
13
Apr 1, 2007 06:19 PM
cvcrcer
Jul 6, 2005 01:33 PM
