Looking for amp and sub recommendations...
Old Apr 11, 2005 | 10:25 PM
brentmc79's Avatar
Default Looking for amp and sub recommendations...
I'm doing a little research for a project that I'm gonna work on this summer. I'm planning on building a fiberglass enclosure to go in my spare tire well. It will hold either two 8" subs, two 10" subs, or one 12" sub. I'm looking for recommendations because I'm not a stereo guy. I know how to install decks and amps and whatnot, no problem. I just don't know what brands/model of subs are good, and what amps would work well with them. I'm not looking for pounding bass. I just want a little bit of bass to go with my upgraded factory speakers. Also, I'm not trying to break the bank either.
So, basically what I'm looking for are some good sub/amp combinations, and about how many cubic feet the sub(s) require as this will play an important role in determining which sub(s) to get. I think I'll probably have about 1.5 cubic feet total to work with. I may even be able to push that to two if necessary.
thanks,
Brent
Old Apr 11, 2005 | 11:26 PM
idriveadelsol7's Avatar
Default Re: Looking for amp and sub recommendations... (brentmc79)
how much are you willing to spend? i was going to use the amp i have to sale in my signature to power a 12" jL w7.
in my accord i had a panasonic dfq-700u (not sure), 2 10" w3's, a fostgate 800x2 (older models), and a kenwood 320x4 for my mb quarts all around. cost me 1000$ forgot all the specific names... sold it all.
Old Apr 12, 2005 | 08:09 AM
brentmc79's Avatar
Hmm... I don't know exactly how much I want to spend, but I'm sure it'll be less than $1000. Probably more like $300-500.
Old Apr 12, 2005 | 01:31 PM
Default Re: (brentmc79)
300 will get you an ok headunit. that's bout it...
Old Apr 13, 2005 | 02:19 PM
brentmc79's Avatar
Default Re: (deLasoL7)
I've already got a head unit, so that doesn't matter. After looking around, I realized that if I want to get something decent then I'm gonna have to spend a little more. I'm thinkin I might go with one 10" W6, so what would be a good amp to push it?
Old Apr 16, 2005 | 01:19 PM
t0ekn3e's Avatar
jl 500/1 but they run like 300 used
Old Apr 16, 2005 | 06:11 PM
GSteg's Avatar
my 12" image dynamics IDQv1 dual 4ohm.
$100 shipped
never been used, just slight scratches on the bottom plate.
i'm sure someone else can clue you in about this sub
If you plan to get the 10w6, you will want an amp that is stable down to 2ohm (3ohm in parallel, but its easier to find spec at 2ohm) and puts out about 500w at 2ohm. So when the amp sees 3ohm, it'll put around a theoretical 325w or so.
Likewise, there are a million amps out there that are able to put out that much. Do you have any preference in brand?
Old Apr 17, 2005 | 01:06 AM
Default Re: (GSteg)
NEVER buy used audio equipment. and "REFURBiSHED" means some **** happened to it to cause it from functioning correctly. check this out for an example... even though it's "fixed" why do cars carry "accident" titles even thought they've been "fixed"? go figure.
Old Apr 17, 2005 | 04:12 PM
GSteg's Avatar
There is nothing wrong with buying an amp used.....
just as why here is nothing wrong with buying used cars
Old Apr 18, 2005 | 05:06 PM
t0ekn3e's Avatar
^^ yup test out the equipment before you phurchase it just liek test driving a car
Old Apr 18, 2005 | 06:58 PM
Quetzolcotl's Avatar
Default Re: (t0ekn3e)
i've got some diamond audio cm310d4's. they are awesome. got an extra 10" for sale for $70 if interested. 1000 watts rms in a sealed enclosure.
Old Apr 18, 2005 | 10:51 PM
brentmc79's Avatar
Default Re: (Quetzolcotl)
I appreciate the offers guys, but like I said, this is a project for sometime this summer. I wish I had the money for it right now, cuz I need some bass.
yee SERIOUS
Audio / Security / Video
22
Apr 23, 2009 11:40 AM
imadigitalgod
Apr 22, 2007 06:40 AM
adrian1281
11
Jun 4, 2003 01:59 PM
