looking
Old Dec 19, 2005 | 03:37 PM
loup05's Avatar
Default looking
looking for some new front door panel speakers for my 95 accord lx. but i dont know the size. plus i want to know what speakers are the best for under 80 bucks (xmas present)
Old Dec 19, 2005 | 06:48 PM
fcm's Avatar
fcm
Old Fart
Default Re: looking (loup05)
Maybe a set of Pioneers standard 6.5" slim lines http://www.mjmautoinnovations.com/honda.htm if you are looking for something plug and play, don't forget STANDARD 6.5" not an over-sized 6.5" or you will have to make mods so they will fit.
Hint.. if the speaker has 4 mounting holes it is probably an oversize 6.5" like this... http://www.dualav.com/product_...d=403
if it has 3 mounting holes or multiply holes it's probably a standard 6.5" like this... http://www.dualav.com/product_...d=406 94
Old Dec 22, 2005 | 10:35 AM
loup05's Avatar
Default Re: looking (fcm)
so if it has 3 screw holes or more i can keep the stock cover over the speakers?
Old Dec 22, 2005 | 02:00 PM
fcm's Avatar
fcm
Old Fart
As long as a coax mounted tweeter does not stick out too far, to be sure the speakers you get must have a mounting hole diameter of 5" +/- 1/8" if you do not want to do any cutting it's mounting depth must not be more then 1.75", you can get away with a 2.25" by cutting a hole for the magnet in the back of the oem plastic speaker mounting bracket, any deeper then that and you will have to install depth reducers, [MDF rings] to bring the speaker out farther, max is about .75" depending on speaker before it interferes with the stock grill, of coarse a speaker that does not have a tweeter sticking out will allow for a thicker depth reducer.
If you are looking for something that is "plug and play" take one of your speaker mounts with you to some of your local car audio shops and just ask what will fit, have a listen, then just check and make sure the speaker will fit. 94
Old Dec 24, 2005 | 02:02 PM
loup05's Avatar
iight man thanks a lot latez
20-EM2-05
Audio / Security / Video
16
Sep 16, 2010 10:16 PM
NACvicSi
Sep 7, 2008 09:38 PM
fleetmack
Oct 15, 2004 03:30 PM
ForceXVII
Mar 9, 2003 08:48 PM
