Lightweight/Small Subs?
i've been using a set of 8" MTX subs, I think they were about $50 a piece (this was about 4 years ago, and I love them. I have gotten many coments from people that can't beilive they are only 8s. The key is to build a propper size box and not over power it with a large amp. I have 60 watts going to each, and they are plenty loud enough for me, they are not ground pounding but fill out the sound quite nicely
I want to be able to hear later in life
look into lighting audio stuff- Volfenhag too. check nexxon, thiers all kinds, you just have to look. I have heard most so just ask me about some you think are a good deal.
peace-colton
peace-colton
Volfenhag specs
10" 800watt DVC Cast Aluminum Subwoofer "The German Concept"
*800 Watt, 10" Dual Voice Coil Subwoofer *400 Watts Continuous *800 Watts Max *4 Ohm Per Coil *Efficiency: 88.6dB 1W/1M *Cast Aluminum Basket *Dual 4 Ohm Voice Coils for 2, 4 or 8ohm *operation *Bumped & Vented T-Yoke *High Temperature 4-Layer Voice Coil *Double Damper *Heavy Duty Industrial Magnet Structure *Protected/Shielded Tinsel Lead for Improved Excursion Ability *Gold Push-Type Terminal Posts *Ships In Custom Designed "Treasure Chest" Packaging *5.71" Mounting Depth *Fs: 32Hz, *Qts:0.462, *Vas: 1.24 cu. ft., *Qes 0.543, *Qms: 7.621
$95
pretty nice deal.
$95
pretty nice deal.
Volfenhag??? Kidding right???
Anyway if you're looking for a good sub 10" or under you could try the image dynamics ID8 V3's. They are supposed to be a huge step up from the ID V2's and the V2's were pretty sweet.
If you want what would be the ultimate 8" then you would probably have to go for the JL Audio W7 8's. They are the most insanely huge 8" woofer I have ever seen!!!!
GrillZ
Audio / Security / Video
24
Nov 28, 2006 11:00 AM
AlphaKennyWun
10
Feb 7, 2002 02:41 AM
nEoMuGen
Oct 16, 2001 08:31 AM
