led scanner
Old Aug 8, 2007 | 03:58 PM
mistahmac's Avatar
Default led scanner
so i guess i need help on a 3 wire led scanner. i have tried everything and failed. the scanner is either always on or off. i bought the streetglow led scanner and it has 3 wires coming off of it. black= constant ground, yellow = constant power, and blue = to activate the led. they say that the blue goes to the ground on the previous led, but when i do that, its always on. i guess what im asking is there a ground on my alarm system or car that is activated by my alarm and not constant?
Old Aug 8, 2007 | 04:46 PM
JSPECSIR's Avatar
Default Re: led scanner (mistahmac)
hook it to your ground when armed output. if you have a starter kill relay you will need a diode to isolate it also.
Old Aug 8, 2007 | 06:25 PM
mistahmac's Avatar
on my alarm, it doesn't have a ground when armed. all the grounds are constant grounds.
i have a blackwidow 2 way alarm.
SoloRiddinMR2
Audio / Security / Video
Dec 20, 2007 04:19 PM
mistahmac
Aug 8, 2007 03:57 PM
Thizzed Out
10
May 28, 2007 08:47 PM
Jdmglenn
Oct 20, 2006 05:38 PM
ghettocrxsi
Sep 7, 2002 01:18 AM
