Kill switch using high beam lever
Old Sep 15, 2012 | 09:49 PM
ninjaturtleEG's Avatar
Default Kill switch using high beam lever
How do I wire it if I want to use the high beam lever as an ignition kill switch? So that the high beams have to be on in order to start the car?
Old Sep 16, 2012 | 06:42 AM
Default Re: Kill switch using high beam lever
Bump
Old Sep 16, 2012 | 07:05 AM
sxysweed's Avatar
Splice a relay coil into the wire for the highbeam, use the switch part of the relay to control whatever you're killing. Simple enough.
Old Sep 16, 2012 | 07:57 AM
ok can anyone tell me what exactly i'll have to connect to the 85,86,87,87a, and 30 pins on the relay please?
Old Sep 16, 2012 | 09:20 AM
KleinMein's Avatar
10 Year Member
#86 to ground anywhere.
#85 to high beam switch. Don't cut the wire, just pick the 12V from there after the switch.
#30 and #87 to whatever you want to cut (ignition), cut the wire you want to control and connect cut ends to the two terminals.
#87a is not used.
#85-#86 is the coil. So when your high beam switch is turned on, you give power to the coil from #85, and it grounds through #86. When the coil is powered, terminals #30 and #87 are closed, and your circuit is enabled.
But why do you want to control the ignition from high beams? What shall you do at day time? You should always have your high beams on in order to drive your car!
Old Sep 16, 2012 | 10:29 AM
rjr162's Avatar
#87a is not used.
To fix this slightly, 30 and 87 to the starter line at the ignition (saying and wire you want to cut is just a bad idea). Let's say you cut ignition so nothing kicks on unless you have the high beams on... well that also means your car would shut off while driving if you turned the high beams off...
Old Sep 19, 2012 | 04:11 AM
ef92b's Avatar
use a latching relay type.
http://www.omron-ap.com/FAQ/FAQ02822/index.asp
Old Sep 19, 2012 | 05:31 AM
deucedeuceEK's Avatar
even just a switch to keep any lights coming on could be a useful kill switch. A car driving at night with no lights kind of stands out.
6genocide6
Nov 28, 2024 03:30 AM
jjos
Audio / Security / Video
Apr 26, 2016 02:09 PM
fryman
Jul 27, 2008 04:27 PM
FGride
Apr 26, 2006 12:43 AM
jmoney85
May 7, 2004 01:40 PM
